Question about Sewing Machines
Espree embroidery machine just plugged in set up machine hit start button complete machine shut down I have changed needle but instructions say raise needle but wheel won't turn or do anything help
  • 482 Answers
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Posted on Dec 16, 2007
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
  • 5 Answers
SOURCE: Needle hits the plate that is over the bobbin.
If possible hoop the item. I have found that any item that has any thickness causes the presser foot to be pushed forward and the needle hits it and breaks. If you can press the item to lessen the thickness this may help. I spoke to Singer (I am a Singer dealer) and they did not have any help for this other than to recommend that the owner cut out the back of the foot. I don't think that would be a solution as it would be difficult to cut out the back of the foot and still have smooth edges, also it would cause the foot to be weak and possible break or bend. Good Luck
Posted on Feb 26, 2009
  • 23 Answers
SOURCE: Needle keeps catching the embroidery foot and breaking
Happened to me to All I did was to press the embroidary foot a little backwards and check if the little arm that rest on the shaft that goes up and down is seating correclty.
Posted on Mar 31, 2009
SOURCE: needle hits inside of bobbin case.
Posted on Mar 03, 2010
The tension will not stay set . It sews great and then suddenly starts looping!! Like carpet!!and no bobbin shows through on back side at all help!!!
Ewww! Wondering if the tension mechanism has gone haywire.
First, change the needle. (Is the thread still in the correct path or has it "jumped" out of place? If so, try slowing down the machine.) Remove the thread. RAISE the presser foot to insure the thread seats properly in the tension disk and rethread from the beginning. Check that the bobbin is threaded properly. Check the tension setting and retest.
If it is still malfunctioning, it may need service.
Mar 09, 2016 | Janome MB4 Four Needle Embroidery Machine
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
How do I change a needle on a brother 770?
same old way as all machines loosen the screw/clamp and pull it down
Feb 12, 2015 | Brother PE-770 Embroidery Machine
At start up machine says press needle position button. All that happens is the motor revs up then says safety feature has been activated. Any ideas?
I used this machine in my middle school classroom. That message was in the first start up of the machine, I think it just resets the machine. The larger model also has a beginning reset button that just adjusts the arm of the machine. Is the machine working fine after the reset? Hopefully "sew"
Jan 13, 2015 | Brother PE-770 Embroidery Machine
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Mar 20, 2009 | Singer CE-200 Quantum Futura Computerized...
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Need service manual for baby lock espree em2 embroidery machine
i have the manual and quick reference guide for the babylock espree. i can make you a copy for $25. if you are interested, send me your email address and i will request payment via pay-pal. thanks much.
Nov 06, 2007 | Sewing Machines
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
