Reseting my pass woard - Computers & Internet
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: pass woard note opening
Step 1:
if you mean unable to open laptop due to password
The password, otherwise known as the BIOS password that has been made into part of the Toshiba Satellite Laptop design, was built in for security reasons. However, Toshiba has also made life a little more difficult for those who have accidentally set the password, have forgotten it and don't know how to reset it. To prevent these troubles, there are routes to resetting or deleting the password completely from Toshiba laptops, including the Toshiba Satellite.
Making the BIOS Password Removal Tool b> There is a connector plug that can help you with removing the BIOS password from your Toshiba Satellite laptop, including model numbers 1415, 1800 and Pro 6100. In fact, they work on most Pentium III Toshiba and Pentium IV Toshiba laptops. To make this tool, take the DB25 connector off of your printer. Remove the screws to take apart the plug. When you take it apart, you will see a bunch of wires there which should have enough length to strip and solder them. The pins on the connector are marked between 1 and 25, so connect the wires together from the following numbered pins: 1+5+10, 2+11, 3+17, 4+12, 6+16, 7+13, 8+14 and 9+15. Some of these may already be connected inside of the plug. Insulate these groups of wires with electrical tape. b> Using the BIOS Password Removal Tool b> Connect this plug to a parallel port in your laptop and turn the power on. This will take you past the password setting stage and right into the operating system. If you are not comfortable with making this tool yourself, you can purchase it online. It will save you some time and effort. Check the list of laptops with which it works to make sure that yours is one of them. Other Methods There are two other methods that you can use to remove the password from the computer. One is the option to buy the guide online, but you don't find out what the instructions are until you have paid for the product. If you are not comfortable with this option, then you can try the following option. When you start the computer you will see the KeyDisk, which is the 'A:' prompt. When you see this prompt, type in 'SBFIXMBR'. This will take you through a number of instructions. Follow these and it will take you past the BIOS area and into your operation system. You can also call Stratum or visit the Toshiba website and download the Toshiba BIOS Update. This update can be used to flash the BIOS, although in some cases, you will have to reinstall your operation system and will not be permitted access to BIOS at all.
How to remove BIOS password from Toshiba laptops
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
Posted on Feb 24, 2013
Pass woard note opening
Step 1:
How to remove BIOS password from Toshiba laptops http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
Feb 24, 2013 | Toshiba Satellite 4070CDT PC Notebook
I forgot my family settings pass code and reset code for the xbox 360
Reset a Forgotten Pass Code To reset your Family Settings pass code after you've forgotten it:
  1. From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
  2. Enter an incorrect pass code.
  3. You will be told that your pass code is incorrect. Select Reset pass code.
  4. You will then be shown your pass-code question and asked to answer it.
    Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
Jul 20, 2011 | Video Game Consoles & Games
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jan 24, 2011 | Microsoft Xbox 360 Console
A couple of years ago i made my xbox live account and accidentally set the family settings to high now that im using my xbox agian i cant really do anything on live since i dont remember my password or...
spacer.gifReset a Forgotten Pass Code
Oct 16, 2010 | Video Game Consoles & Games
I put on a family timer on my sons xbox and i can remember the pass code
Aug 25, 2010 | Microsoft Xbox 360 Console
Can u give all the combinations for family setting problem.
Reset a Forgotten Pass CodeTo reset your pass code after you've forgotten it:
Aug 30, 2009 | Microsoft Xbox 360 Console
Need to reset pass word/ without reset disk
Just login using SAFE MODE
Then reset password
May 30, 2009 | Acer Aspireā„¢ T180 PC Desktop
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
