Question about Logitech USB Desktop Consumer Microphone
Microphone works when tested in Windows XP but stops working
When I open the game. After the game is opened I tried to test the microphone in the game and in windows and it wont work at all. What can I do to fix this problem?
    Problem Solver:
  • 12 Answers
Sounds like the game has it's own i/o (input/output) settings. Go to preferences or settings in the game menu (may be under options) and select your input as this mic and not the internal microphone that it has probably defaulted to. Make sure you have your mic plugged in before you start up the game though.
Posted on Jul 29, 2009
Built in microphone not working
Hello Lynne.
Please try opening controll panel - under views click either small or large
icons. Look for sounds and open it. I think there are microphone options
listed there.
Dec 20, 2011 | Toshiba Satellite P305-S8814 Notebook -...
I have a HP laptop, and the internal mic has never worked? is there an upgrade i need? also, is the sound card automatically in the computer or is that something extra? i thought since it had the internal...
Changes in software, settings, or drivers can cause a microphone to stop working. Before performing any of the solutions in this document, test the equipment. After testing the equipment, select the document section that applies to the issue and follow the instructions. If the microphone recently stopped working, it may be necessary to use the Microsoft System Restore feature to correct the problem. Windows Troubleshooting Windows troubleshooting can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run Windows Troubleshooting first before you manually correct problems. To run Windows Troubleshooting, follow these steps.
  1. Click Start , enter troubleshooting in the search field and select Troubleshooting from the list.
  2. Under Hardware and Sound, click Troubleshoot audio recording and then click Next when the Recording Audio window opens.
  3. Select the device you would like to troubleshoot and then click Next .
If a recommended action displays, select Apply this fix or Skip this step to continue to search for other problems. If your problem has not been resolved, continue to manually troubleshoot using the rest of this document.Test the equipment Verify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
Dec 01, 2010 | HP Pavilion dv2000t Notebook
Plugging in Mic ceases sound playback
The drivers are working, but you apparently have a non asynchronous driver, meaning it either records, or plays, but has trouble doing both.
Gamers usually like their sound a bit beefier than the standard AC97 chip common with mainboards can produce, I would suggest first making absolutely sure your machine is clear of virii, etc,, turn off the windows sounds, because most earlier built-in sound chips cannot multi-client, and if you still have the problem, go for a USB sound box like the M-audio Transit, for around $100, it will give you high definition sound, both in and out, and you won't have to open your PC to install it.
Mind, I am not a shill for M-Audio, but for gamers, you really need the 24bit/96KHz out, to match your game's audio.
You will also find your games may run more smoothly, as the audio role is now in the little box, rather than your CPU.
The digital out can go to your home theater system, the 5.1 really makes it more fun.
Dec 08, 2009 | Computers & Internet
I CAN SEE OTHER PERSON AND THEY CAN SEE ME BUT CANT HEAR ME BUT I CAN HEAR THEM .WHAT HAVE I DONE WRONG
The problem is either the microphone is not connected/faulty or the wrong microphone is selected in the Skype Audio setting.
To check if the microphone is working - go to Start - All Programs - Accessories - Entertainment - Sound Recorder and do a test recording.
If the sound is doesn't work then open Device Manager - Sound, video and game controllers and check the microphone is enabled and working. If it isn't listed or has a yellow ? against the microphone then you need to install the microphone device driver.
If the microphone is working then open Skype then click on Tools tab -then Options - Audio Settings - then in microphone setting and click on the microphone list to select your model microphone. Then Save your settings.
To test your microphone settings then go to Contact list and select Echo / Sound Test.Service and follow the instructions. If this works then your friends will be able to hear you,
Nov 07, 2009 | Logitech Quickcam Chat Webcam
Microphone des not work
There are two items you'll need to check. First, when you boot your system press the Delete key to enter the bios. Open the Advanced tab.
Make sue your Audio is set to [Enabled].
For windows XP operating systems check within windows Device manager. Click the start button, open control panel. Double left click on the "System" icon to open. System properties window will open. Click on the Hardware tab than click on the "Device Manager" button. Scroll down through the icons until you come to: Sound, video and game controllers. If there is a problem with the driver you will see something like. Unknown pci controller or simple pci controller. If you do not see something either of these than there is nothing wrong with your driver software. Make sure you setup your microphone. Open the windows "Control panel". Than open, "Sound and Audio Device". Click on the Audio Tab. Under, "Sound playback" the Default device should read as; Realtek AC97 Audio. Now click on the Voice Tab. Under "Voice playback" the Default device should read as; Realtek AC97 Audio. Lastly, you need to click the "Test hardware" button. Follow the instruction from windows. It wouldn't hurt to check windows for updates. If you still do not have use of the microphone than the intergraded sound controller is defective. This can’t be repaired. You can disable the intergraded sound controller in the bios. Than buy a PCI sound card and add it into an opened PCI port.
Hope you find this helpful.
Mike
Nov 03, 2009 | Intel D865GVHZ Motherboard
It wont open
Because your window instol is not right so the game not start and your pc is not bigger to start this game
Feb 08, 2009 | Electronic Arts Counter-Strike: Source for...
Microphone does not seem to work
Go into control Panel and go to SOUNDS. Click on the icon and when the window opens, click on the RECORD and when that window opens, click on the speaker and SET AS DEFAULT. Should work okay then Hope this helps. Bud
Dec 26, 2008 | Logitech QuickCam Pro 5000 Webcam
Microphone doesnt work
Games that come with accessories like microphones can be exchanged(for same product) within return policy. Do so.
Apr 24, 2008 | Sony PlayStation 2 (PS2) Console
Webbcam works but no sound or microphone
First, make sure you have a webcam with a microphone, and run any test software the webcam came with to check and make sure it is *supposed* to work. Next, open SOUND PROPERTIES through the CONTROL PANEL and then from the menu go to ADVANCED and RECORDING and OKAY, to bring up a volume array that includes the control MICROPHONE. Then, dig around to make sure MICROPHONE is the input being selected for amplification, and try ADVANCED on MICROPHONE and turn on BOOST if it has this control. You can test whether all of this worked by opening SOUND RECORDER from ACCESSORIES and making a short recording of yourself cursing the machine and everyone who designs them. If it plays back normally, try your web camera again. If it still has no sound, the problem is in the settings of the web camera itself. Open whatever software it came with and check setting like MUTE and MICROPHONE VOLUME are set correctly.
Good luck...
Nov 13, 2007 | Acer Aspire 5610-4648 Notebook
Microphone and speaker problems
Do a virus scan first FREE ANTI VIRUS Try here its free http://www.kaspersky.com/kos/eng/partner... If you can not access or open IE right click in and select Properties then set the homepage to Blank! SOUND RECORDING\MIC ON USB CAMERA In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester.
Sep 20, 2007 | Audio Players & Recorders
Logitech USB Desktop Consumer Microphone Logo
256 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
