Question about Refrigerators
How do you remove the icemaker - Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Icemaker is generating heat and melting items near it - Amana SR25F1L - how do I disconnect power to icemaker?
The icemaker has a plug on the back of it,by removing the screw from the bottom support bracket and then then 2 from the top of it the icemaker could be removed from the freezer wall so it could be unplugged.
GENE
Oct 08, 2011 | Amana Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Have an LG icemaker that is not working and needs removing. Tech showed me how to do that if it happens to not work again. I have the screws removed but can't get it unplugged (icemaker only) is there a...
there are catches on the plug that secure it from accidentally unplugging,some you squeeze and some have tabs in the side of the plug that need pressing to release the plug
Mar 22, 2011 | LG LFC20740S
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
I have a 15 year old GE fridge with an icemaker that has started
You can buy a new icemaker from Home Depot your is probably rotted. Unplug the appliance and unplug the icemaker then remove the screws.
Sep 24, 2009 | Refrigerators
How to replace alumalastic in u-line icemaker
Hi
Not all U-lines have alumalastic under their icemaker. What model do you have? Alumalastic will come with the icemaker with directions on how to put it on. It's a caulking material that is spread under the icemaker to cover the heater and sensor tube. If you remove your icemaker you should see it if it needs it.
Jul 29, 2009 | U-Line Icemaker
Water leaking at fill valve or coming from ice tray?
I doubt the mold would crack. Do you see flaking in the ice? Or remove front cover on icemaker and check to see if the gears are corroided. If so it might be the faceplate needs to be replaced. Now depending on your model to remove icemaker you have 3 screws there is 2 screws on the side wall. FIRST remove the back panel and pull the sensor tube out and also disconnect the wires for the icemaker. There will be alumalastic on the bottom of icemaker and it needs to be replaced when you remove the icemaker.
By replacing the faceplate you will correct 2 of possible problems. Part#150
Jun 19, 2009 | U-Line Icemaker
Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Icemaker froze up and I want to remove it so that can thaw it out
there is 1 screw on the back right hand corner of the icemaker remove this screw then remove the wiring cover that this screw held in place. the icemaker will then slide straight out you will then unplug the icemaker at the wiring harness and be able to completely remove icemaker. thanks for using  fixYa peyton
Feb 17, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
