Question about Refrigerators
Hi there, We have two explorer refrigerators. One of them suddenly stopped working last night. They work with a transformer that converts 110 t0 210. Please help.
  • 1462 Answers
SOURCE: Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
Posted on Apr 16, 2007
sknerdish
  • 53 Answers
SOURCE: iphone touchscreen not working
try fully charging the battery
Posted on Feb 18, 2009
landsend
  • 1066 Answers
SOURCE: 04 350z convertible
check for voltage to the top motor and the relater fuzes and relay.
Posted on Mar 13, 2009
  • 2006 Answers
SOURCE: refrigerator suddenly went out last night. there
According to the service manual if it doesn't work on AC but works on gas it should be one of the following AC Volts
Fuse
Heating Element
Wiring
Lower Circuit Board
Where you say there was a clicking sound you might also want to make sure the DC volatage is correct.
Here is a downloadable copy of the service manual.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Posted on Jul 14, 2011
Testimonial: "Amazing how quickly I received an answer. Great service."
SOURCE: Hi, I have a Kenmore side by side refrigerator
small glass 15 amp fuse on top of unit. remove cover and replace fuse
Posted on Nov 06, 2011
How to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Jul 01, 2014 | Dometic RM2652 Refrigerator
Lg refrigerator is not working at all
Unplug the refrigerator for ten minutes then plug it back in. If it starts to cool you need a new control board.
Feb 28, 2014 | LG Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Refrigerator suddenly went out last night. there was some clicking sound from the converter earlier?? I think it is still able to work on gas. It started cooling in the freezer
Fuse
Heating Element
Wiring
Lower Circuit Board
Jul 14, 2011 | Dometic RM2652 Refrigerator
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
Iphone touchscreen not working
Apr 15, 2008 | Apple iPhone Smartphone
Change gas/110volt fridge element to gas 240volt
You need transformer converter 110 to 240VAC.
Regards ,
Edgz
Jan 26, 2008 | Refrigerators
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
