Question about Kitchen Appliances - Others
Power cord for Townecraft liquid core skillet cat. No. 92010....1200 watts.. 120 volts
  • 52 Answers
SOURCE: I need to replace the 120 volt AC wall adaptor
Here is your link to buy it.
http://www.centurytool.net/5140044_04_Charger_W_Small_Jack_p/5140044-04.htm
Posted on Jan 11, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Need a power cord
Here is the West Bend site link where you can order the part:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2355&secid=54&linkon=category&linkid=37
The "thermoplug" should be what you need.
Posted on Jan 23, 2009
SOURCE: powercord replacement
This is a standard high-wattage appliance cord -- you can find one at any appliance parts store.
Posted on May 29, 2009
bestcookware
SOURCE: power cord for hoover electric skillet
Hello: We just had one of those exact heat controls and sold it in our ebay store, I can send you some photos to compare the controls. That specific heat control model is very hard to find and normally you do not see them, I have not found them anywhere else.
We have a cookware store on ebay for the last 5 years and carry some replacement parts for the vintage appliances - you can email me through the ebay store - our ebay store ID is bestcookwareforless! (with the exclamation point at the end) or email me at jasmine@bestcookwareforless.com and I will add you to my customer wanted items list. We get excellent pre-owned used heat controls in all the time and are more than happy to help our customers locate a specific one.
All is not lost, so don't throw out your favorite Hoover skillet - they are built like a tank, made to last and very hard to find nowdays. Keep her and get her a new heat control and she will last another 50 years (smile).
Hope we can help you!
Kindest Regards, Jasmine
Posted on Jun 26, 2009
  • 351 Answers
SOURCE: need power cord for ge electric skillet
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
Posted on May 05, 2010
Why can't I find a replacement power cord for my Rival electric skillet Model SS 120
What is the model of the cord you need. Also what is the wattage of you skillet?
Jan 29, 2015 | Rival Kitchen Appliances - Others
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
I'm looking for one skillet power control for Rena Ware fry electric pan Cat. 17530
Rena Ware Electric Skillets use the same control as West Bend WB-1 . The back of the Rena Ware Control does say WB-1. Mine is 1500 watt.
You can find the WB-1 eBay for various prices. A generic heat control will probably work as well if it is the same wattage. I have a Saladmaster control that also works for this skillet.1_26_2012_12_42_14_am.jpg
Sep 07, 2011 | Precise Heat KTES2 Electric Skillet
I have a PC 6500 watts generator. The 120 volt receptacle is already occupied. I have an appliance120volt/30 amps that has a 10/3 cord and is furnished with a standard 3 pin twist plug. How can I used...
How many amps is the 120/240 volt circuit? I can tell you how to split it into two 120 volt circuits. A twist loc cord end, a piece of four conductor cord, two electric boxes, two receptacles would be needed.
How many amps?
Nov 12, 2017 | Porter Cable 6,500 Watt Contractor...
I need a replacement cord for The Lektro Maid 1400 Watts 120 Volt frying griddle It is two prong.
Fixya does not sell replacement cords for The Lektro Maid 1400 Watts 120 Volt frying griddle.
Feb 01, 2011 | West Bend 72122 Electric Skillet
If using with a power strip or extension cord, how many amps does the iron pull -- it is 1700 watt the kind I have
Power = Current x Emf
Current = Power / Emf
Current - Amps
Emf - Volts
Power - Watts
Current = 1700 watts / 120 Volts = 14 Amps
If you live in Europe then -
Current = 1700 watts / 240 Volts = 7 Amps
Be sure your breaker and extension cord are rated for the amperage.
Nov 19, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Checking power consumption
you need a clamp on amp probe, a multimeter wont hack it. if you can get a amp probe, you first seperate the wires on your cord and then place the probe over one of the wires only this will give you your consumption. by the way, your approx usage of watts on a 26 inch lcd tv would be 160 watts. models do vary.
Mar 29, 2008 | Televison & Video
Lost Power Cord cant find a new one
I lost my power cord for my Electric skillet and called Wal-Mart number on the back of the skillet and they said it would be able to be exchanged for a new skillet with a cord if purchased within 2 years even without a receipt or a box :-)
Aug 05, 2007 | Rival S16 Electric Skillet
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
