How do I tell if my lop eared rabbit is a boy or girl its 6month old?
  • 43 Answers
SOURCE: sony rabbit ears
The "Horse Shoe Like Ends" on the leads are installed under the Screws marked ANTENNA and then the screws tightened. If No Screws then your Rabbit Ears do not hook directly to this TV. Is there a connector comming out of the back that is Threaded? If YES, then this is your antenna connector (R59) and will require an Adapter for the rabbit ears. Available at Radio Shack.
Posted on Feb 04, 2008
SOURCE: TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Posted on Jun 08, 2008
SOURCE: Magnavox TB 100 MW9
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Posted on Jun 24, 2008
bestdarngood
  • 3037 Answers
SOURCE: cancelled dish & hooked up rabbit ears. no local channels
Digital channels require a really strong signal to work well compared to analog. Can you get any analog channels through the tv itself? You will probably need to get a large antenna mounted outside to get these channels to work especially if you are a distance outside the city from where the broadcast is coming from. Sorry for the bad news. It is one of the bad things about the digital transition.
Benjamin
Posted on Mar 25, 2009
  • 30 Answers
SOURCE: Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Posted on Jun 15, 2009
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
How to hook converter box to rabbit ear TV
Hi, Sorry Vicki, Play Taps for the Relic. Those old tvs don't have the type of tuner that will even accept an input from a converter. The good news is there are quite a few good tvs out there that don't cost a fortune and you will really like the new picture they are capable of. Good Luck to you!
Mar 19, 2009 | Televison & Video
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Digital to Analog Change Over
you are fine. if you do not get a pic or sound it could be that the rabbit ears you are using are not compatable with your box. you may need a diff. type of rabbit ears
Dec 30, 2008 | Zenith C27A24T 27" TV
Magnavox TB 100 MW9 STB Converter Boxes I'm trying to solve the antenna/rabbit ear connection from this converter box to the t.v. I only get a pic when the rabbit ears are connected to the back of the...
Jun 11, 2008 | Televison & Video
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sony rabbit ears
Feb 04, 2008 | Proton MM2701VT 27" TV
Televison & Video Logo
Top Televison & Video Experts
