Question about Olympus Cameras
How does the midtone adjust work on the new up date for the Olympus OMD_5ii
Olympus TG 820 - will not keep date and time
There is a fault in the camera return for service , if new it should be repaired for free.
Mar 13, 2015 | Olympus Cameras
Omd code P1775 came on
This is a transmission issue that is related to the transmission not being able to signal a problem.
Feb 13, 2014 | 2006 Mitsubishi Raider DuroCross
Date time stamp for olympus c-5000. How to turn
I had the same problem. I wanted to set my Olympus C5000 Zoom to automatically date stamp photos. After going through the entire manual, I had to call Olympus directly. They told me that none of their cameras have an internal date stamp feature. They said that the date stamp lowers the quality of the picture, so they choose not to have the feature available. However, you can manually add the date and time stamp through the software that comes with the camera, just before you print the pictures. Hope that helps...
if you need help with that manual go to http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/ and get our off the list.
It is on there!!! about the middle of the page.
Sep 10, 2009 | Olympus Camedia C-5000 Zoom Digital Camera
The date doesn't show up when I print pictures from my Olympus FE-280 camera. How do I get he date to print on my photo's?
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Jul 11, 2009 | Olympus FE-280 Digital Camera
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
Jun 20, 2009 | Olympus FE-230 Digital Camera
Can't find how to set date/time stamp on picture
Jun 08, 2009 | Olympus i:robe IR-500 Digital Camera
Date & Time Stamp on PC
Jun 06, 2009 | Olympus FE-210 7.1 MP Digital Camera w/...
Need date stamp on pics taken with my Olympus Camedia c-60 camera. Cannot figure out how to make it work that way. Any ideas? Thx.
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order or print reservation that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Camedia Master or Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Jan 28, 2009 | Olympus Camedia C-60 Zoom Digital Camera
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Date Imprint
Throw the cam and buy a good one, this camera was bought by me to record the site photographs but with out a date imprint on them they are not even worth a tissue paper.
Feb 28, 2008 | Olympus Stylus 770 SW Digital Camera
Cameras Logo
43 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
