SOURCE: Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
SOURCE: Rowe CD-100-C Jukebox
Yes you will require a replacement CD player.
If you are in the USA then Bruce Wentworth is your man.
Bruce Wentworth
A&B Jukebox Repair
56 Old County Rd.
Plaistow NH 03865
Tel: 603-382-6272
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
SOURCE: My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
SOURCE: I have rowe ami jukebox Eagle Laser Star and its
No don't do that. Take it to someone who services amps. They're all pretty much the same. Usually a couple of final-stage transistors are **** or the power supply is troubled. Good luck though!
