Question about Bosch Dishwashers
Just installed Bosch dishwasher - got error code 15
barkencoa
  • 3463 Answers
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
ercupa190
  • 12223 Answers
SOURCE: My Bosch dishwasher has an error code of h:15 any idea what that is?
please go and read the instruction manual section troubleshooting.for to fix the error code.
If you do not have ins.manual go for free download: www. fitness.manualsonline. com or www. retrevo.com or www.manualsfactory.com
sincerely. God bless you
Posted on May 08, 2012
  • 51 Answers
SOURCE: Bosch dishwasher showing e:15 error code.....how do you fix it?
E15 means that unit doesn't think it's getting water
If there is not water inside the tub then you have a problem with your electronic water valve and will need to have it replaced. If you do have water inside but it's still giving you the error, then you have a bad flow meter that iwll need to be replaced
Posted on Nov 18, 2012
  • 34 Answers
SOURCE: What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Posted on Nov 17, 2013
  • 2992 Answers
SOURCE: Error 15 on Bosch dishwasher
Owner's manual troubleshooting. No manual? Try manualslib.com
Posted on May 04, 2015
Error 15 in BOSCH dishwasher model sms69m18gc
E15 error code indicates that there is water sitting in the base of the dishwasher.
Most common reasons:
  • malfunction of the water drainage sensor when the aqua-stop worked
  • the system is clogged
Mar 11, 2018 | Bosch Washing Machines
Our bosch dishwasher shows an error code H:21
There are many reasons why Bosch Dishwasher Error H21 happen, including having malware, spyware, or programs not installing properly. You can have all kinds of system conflicts, registry errors, and Active X errors. The registry on your computer will accumulate errors over time. It's just a fact of life in the computer world. This happens as programs are installed and modified, or even removed.
May 11, 2017 | Bosch Dishwashers
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Bosch Dishwasher fault E 15 explain
Bosch Dishwasher Error Code E15
Fault Condition:No water in dishwasher or not sensing water.
Repair or Check: Tilt dishwasher back and the error code should disappear. While you tilt it press off button to clear. Stand it back to normal turn back on and dishwasher should run normally.
Parts Required:Tilting machine
Hi i found this answer on this link, scroll down the page and it's the 3rd error code (in red) Hope it helps...
https://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Mar 16, 2016 | Bosch Dishwashers
Dishwasher goes through cycle but when finished it is cold and code E..09 appears
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
May 06, 2012 | Bosch Dishwashers
Dishwashers Logo
41 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
