Question about Garden
I would like to get hardware for the wheels spreader and contracter
Can i get replacement wheels for the scotts edgeguard pro spreader
try a mower shop or hardware shop
if they don't have in stock they can tell you where to buy the wheels
Try a shop that sells wheels and castors as they have a good range on the shelf
Mar 25, 2016 | Garden
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
I ave a pro edgeguard broadcast spreader and the spinning wheel stopped functioning
Sorry to hear about the problems you are experiencing with your spreader. We may have replacement parts available. Please give us a call at 877-465-5160.
Hilary @Scotts
Sep 01, 2011 | Scotts Company Scotts Pro Edgeguard...
Where can I get a wheel assembly?
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 1-800-543-8873 at your earliest convenience to check part availability. Hilary @Scotts
Aug 05, 2011 | Scotts 74434 "deluxe" Edge Guard Spreader
I have a i=2 year old Scotts lawn spreader. It is in good shape but the wheels fell apart. Where can I get replacement wheels
I am sorry to hear about the problem with your spreader. We should have replacement parts available to send. Please give Scotts a call @ 1-800-543-8873 at your earliest convenience to see what we can do to assist you.
Feb 11, 2011 | Scotts Company Scotts& Accugreeen 2000...
Repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Sep 06, 2009 | Garden
Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
Aug 27, 2008 | Agri-Fab Agri Fab Spreader
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
