Question about Health & Beauty
I have a pressure button on my machine, 150 to 240 where should I put it before I take my blood pressure
3 Suggested Answers
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Posted on May 14, 2010
    Only memory works on y HEM-711 start stop button does not work . Is it worn out?
    Time for a new machine. That could be the controller or the switch board that is bad. You cannot get parts.
    Oct 06, 2016 | Omron HEM-711 IntelliSense Automatic Blood...
    Replacing leaky cuff
    blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
    press the helpful button and follow me on fixya for more tips
    Blood Pressure Monitors Parts and Accessories
    Blood Pressure Monitor Replacement CuffWalgreens
    http://www.walmart.com/c/ep/blood-pressure-cuffs
    OMRON Healthcare Blood Pressure Monitoring
    Feb 03, 2016 | Health & Beauty
    My Omron blood pressure machine will not pump up
    Check for leaks in cuff and hoses. Put cuff and tubes in water and look for bubbles. Bubbles=hole
    Sep 28, 2014 | Health & Beauty
    PUT IN TIME/DATE ON CVS MODEL KD556 SKU 800231 BLOOD PRESSURE MONITOR, THERE R 2 BUTTONS, START & MEMORY : NO SET BUTTON
    On your model, hold the "start" and "memory" buttons at the same time. After about 3 seconds the month will start flashing in the window. Push the "memory" button until it gets to the month you want. Then hit the "start" button and the day of the month will flash. Push the "memory" button until the correct day of the month comes up. Push the "start" button again, and the hours will flash. Push the "memory" button until the correct hour comes up. Do the same for minutes, and the next time you push "start" it goes into ready mode.
    Apr 07, 2012 | Health & Beauty
    How do you clear the memory on a Walgreens blood pressure machine that has a retained memory
    Press the memory button above the start/stop button. The at the top of the device you will see a clock and + buttons. Press them both at the same time and you will see CLA on the screen. Then the memory is erased.
    Jul 25, 2011 | Walgreens Automatic Wrist Blood Pressure...
    Sunbeam7650 Don't know how to properly set the Pressure Selector
    The switch tells the machine how high to pressurize the cuff when it starts. It needs to somewhat higher than your normal systolic pressure (mm Hg). (So if your systolic (top number) bp is regularly between 100 and 130, set the switch to 160.) Similarly if your systolic pressure is regularly above 130 but below 170, set it to 200)
    I hope this helps.
    Jul 19, 2010 | Sunbeam Digital Blood Pressure Monitor
  • Apr 10, 2010 | American Diagnostic Corp ADC Advantage...
    My centrios blood pressure monitor starts working and then quits with an err 5 what is this?
    Hello there:
    Normally if the blood pressure is too low you will have a error but this could be caused by the battery being low
    So what i would suggest is to first double check the battery by taking it out of the monitor and pressing in the power button and holding it for 10 seconds this will clear the machine now put the battery back in and power up the unit ** note when using the monitor always make sure that the arm is crossed against the heart and that the machine is on the wrist properly and is facing the right way then try this ok?
    Hope this is very helpful for you
    Best regards Michael
    Feb 25, 2010 | Centrios Wrist Strap Blood Pressure...
    Blood pressure machine does not give heart rate infor
    I finally got through to the company customer service person and found the machine has ''gone defective.'' They will pick up this one and send a replacement.
    Mar 19, 2009 | Homedics Deluxe Automatic Blood Pressure...
    WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
    E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
    Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
    Health & Beauty Logo
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
