Question about Cell Phones
Phone number not appearing on my home phone or when they call me
I forgot my password nd i hv changened my numbers pls help me nd gmail is www.0797339568@gmail.com nd the phone is samsung GT-S5300
If you forgot your password; your only option is a 'factory reset'; that will wipe all data & apps (and the password as well). So hopefully you have a backup you can restore afterwards ...
Here's the procedure to perform a 'factory reset':
  • Turn off the phone
  • Press & hold volume up + home button simultaneously, then power on the phone
  • Release volume up + home button if recovery menu appear
  • Scroll down to factory data reset menu, use volume down to navigate and home button to confirm.
  • Phone will automatically restart and now the phone is on factory state.
Jun 22, 2014 | Cell Phones
When I turn phone on it goes off and on
To receive a precise solution we need the model number of your phone but if it's an android based try to press HOME KEY + VOL UP + POWER KEY. Then when Samsung logo appears let power button go and in dump off menu select reset factory using volume buttons. Use home key to accept your selection. Good luck.
Apr 16, 2014 | Samsung Galaxy Proclaim Smartphone
I need a reset code for phone screen locked
There's no hard reset on this phone. Here's what you want to do. If your phone is currently locked on your home screen pres 111111(do not press unlock because it'll only give your 4 spaces, just do it until you see the 1's appear). You should see Options or Service appear,if Options, select options then service, if service select service. You should see reset lock, select it then click yes. It'll ask you for a 6-digit code. This is called the 6-digit service programming code or SPC, just call MetroPCS' customer support and have them give you the SPC, once you've entered it, your phone's lock code will reset to 0000 or the last four digits of your phone number. If it'snot locked it'll be easier for you to enter 111111 on the home screen. Follow the same procedure.
Aug 28, 2013 | Kyocera wild card Cellular Phone
Once a week at 4:00am my GE Simon XT does an auto phone test. At 4:12am it notifies me that the phone test has failed by beeping continuously until I press disarm. How do I get the system to stop running...
You will need the installer code to change the setting. Factory default is 1234. press the up or down arrow until "system programming" appears on display. press "OK" and "enter code" appears. Enter installer code. If it accepts it, "access codes" appear on the display. Use the down arrow until "timers" shows on display. Press"OK". Press the down arrow until "auto phone test tm" appears on display. Press" OK". use up and down arrows to adjust to "off". Press"OK". press "Status" and "timers" is shown. Press up arrows until "phone numbers" is showing on display. Press "OK" press "OK" again press "disarm" press "OK" press "Status" 4 times. You have now completed removing the phone number and turning off the phone test.
Nov 21, 2012 | GE Security Simon 3 Wireless Home Security...
How do i send picture message on a htc
http://www.htc.com/uk/howto.aspx?p_id=283&id=36
this is a good how-to for a multimedia message, which includes pictures.
  1. Press HOME and then tap Messages.
    If the Messages icon is not on your Home screen, tap the All Programs button on the bottom-left corner of the Home screen and then tap Messages.
  2. On the All messages screen, tap Compose message.
  3. Enter the mobile phone number or begin typing the name of the message recipient in the To field. As you enter the phone number or name, matching contacts will appear on the screen. Tap a recipient to add the person to the To field. If no matching contact is found, enter the recipient's phone number.
  4. Tap the text box containing the text "Tap to compose," and then start composing your message. As you near the 160 character limit, a counter will appear in the top right corner of the text box to tell you how many characters are left. You can still continue composing your message if it exceeds 160 characters. A new message is automatically created and attached to your original message, and will appear as a single message to the recipient.
  5. Press MENU and then tap Attach.
  6. On the Attach window, select the type of attachment you want to send:
  • Picture. Opens the Albums application. Tap the album containing the picture you want to use, and then tap the picture to attach it to your message.
Jun 09, 2011 | HTC Hero Smartphone
I tried to delete old content from my iphone and now it will only let me ring emergency numbers how do i reset my phone
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 09, 2011 | Apple iPhone Smartphone
My iPhone is stuck on the white screen but i cant really use it..i tried to restore it on itunes but i cant since it has a passcode but i cant type it in because the screens white and i cant see the...
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jan 27, 2011 | Apple iPhone Smartphone
It won't start it just has apple on screen
hi
try to reset your phone
To reset i Phone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If i Phone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn i Phone off and turn it on again. Press and hold the Sleep/Wake button on top of i Phone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset i Phone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
1.) Shut down the i Phone 3G.
2.) Start up i Tunes
3.) Hold down HOME button on the i Phone 3G
if this was helpful kindly vote for this answer..
thank you
Dec 22, 2010 | Apple iPhone 3GS Black (16 GB)
WINFAX SETUP CLOSES WHEN PHONE NUMBER ENTRY IS BEING PERFORMED
Winfax Pro has been long discontinued software. It also will NOT run properly under Windows XP. That is the problem.
Aug 14, 2009 | Microsoft Windows XP Home Edition with...
GE 5.8 cordless
check that the number 6 key is not stuck down
Jan 16, 2008 | Uniden Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
