Question about Samsung Audio Players & Recorders
Cannot get Dolby atmos through Samsung hwk950 soundbar
What setting do I need on my Yamaha AX-V683 to play Dolby Atmos movies I have compatable speaker system, but the AV does not show me if it's playing the sound in Dolby Atmos.
Pressing the info (several times) on the remote will show what mode it is in.
The sound mode for movies is selected by pressing the movie button on the remote.
May 19, 2018 | Yamaha Audio Players & Recorders
Howdy. My name is Gary Taylor. I have a new, purchased from Samsung, HW-K950/ZA soundbar with Dolby Atmos. functioned perfectly for 1 hr then Arc dropped out. Any suggestions. Gary.
ARC is the audio return channel. Make sure the latest HMDI cable is being used. Check the cable at both ends. There is a start order to the setup and the television unit should be started first, then the sound bar. This includes the power sequence. Unplug the television AND the bar, plug in the Television and power it on, plug in the sound bar and turn it on..
Feb 15, 2018 | Televison & Video
I have an Onkyo TX-NR737 receiver. I just purchased a Sony UBP X800 UHD blu-ray player. I am having no luck in getting the Dolby Atmos to work. what port should Use?
Have you updated the onkyo firmware as Dolby atmos operation requires it
I use input one on my amp for the Sony
video out hdmi port on Sony to hdmi input one on amp the other hdmi port on the Sony is audio only for non 4k receivers /amps
Sep 07, 2017 | Sony Televison & Video
I have a Samsung smart tv and a yamaha RX-V592 there is no optical or hdmi on the reviever. I really would like to listen to my tv in surround sound. What can I do?
You need a new receiver, that unit will only do Dolby Pro Logic and all 5 speakers will play but you have to use the composite audio cables(The red and white cables for audio) to get the audio into your receiver and the yellow is video which you can run thru the Yamaha as well if you want any on screen adjustments that unit may have and refer to your owners manual http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=35288
Net unit make sure it as least 5.1 and you can get Dolby Atmos on a few select models but whatever you get make sure you can pass you video signal thru with HDMI cables or component at the least, a couple of years ago I went from the Yamaha R-V1300 to their RX-A3020 and couldn't be happier, the new one which is the Yamaha RX-A3040 has Dolby Atmos but whatever you get and you are only running it at Dolby 5.1 at least each speaker will be discreet unlike in the Dolby Pro Logic mode you will be running, and 5.1 means 3 speakers in the front and 2 in the back or on the rear sides, so that is your 5 the .1 refers to the subwoofer because it get a one tenth of the signal the rest of the speakers can do so 6.1 means 3 in the front and 3 in the bab plus the .1 subwoofer. My system will do 11.2 but I will be just happy with 7.2 but until I move into a house I run it at 5.1. godd luck and feel free to hit me up with any questions...
Feb 10, 2015 | Yamaha Audio Players & Recorders
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Hi, I have a hwh450 soundbar, I cannot get any volume to TVs, the tv is telefuken
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV.
HW H450 Wireless Audio Soundbar Samsung Home Audio
Jan 04, 2015 | Samsung 2.1 Dolby Digital Wireless...
Ho do I set up atmos on Onkyo
HI Perry, I found this article from Dolby to be super helpful, http://www.dolby.com/us/en/guide/home-theater-setup.html, Thanks JT
Dec 30, 2014 | Onkyo Audio Players & Recorders
Hi...i cannot get sound out off my atmos speakers
The other part of the equation is your source; which is not mentioned in your question.
Your player must also be able to decode Dolby TrueHD and the audio output on it set to Bitstream.
Dec 06, 2014 | Onkyo 7.2 Channel Network A/V Receiver -...
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
