Hi ibr6 failed is on screen i left it fall - Televison & Video
It fell down from 3ft height since then no dispaly screen coming
You probably broke the screen or a cable popped out. I made a video on how I replaced the screen in one.
Mar 05, 2014 | ASUS Google Nexus 7 Tablet
Panasonic rear projection 47 inch
hi you are right this is common fault what needs replacing is the convergance ics theirs 2 of them but whils replacng these you will need any resistors checking for damage also as when the ics start to fail then its usually because a resistor has blown somewhere on the board causing the power to rise or fall and this causes the ics to fail
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Are fiat puntos worth the hassle!!!? all mine seems to do is fall apart and the electrics are all over the place
they dont call them fix it again tommorow cars for nothing (fiat) they are all the same steer clear of anything italian or french all the same rubbish i have constantley having to fix my two neighbours fiats from rattles steering problems windscreen wipers failing radiators failing light flickering i dont think there is an originall part left on it buy german but make it and old mercedes no sensors to fall apart simple mechanics and go on for years without problems thanks ivan
Oct 01, 2012 | 2005 Fiat Punto 1.2
The picture on my monitor is completley turned to th e left, and is now sideways with the task bar on the right, the icons on the bottom and my wallpaper (husbands picture )looking ike he is falling out of...
first hold the keys Ctrl + Alt and use the arrow keys if this fails
if you are running windows Vista or Windows 7 right click on the desktop, and select personalize, when the window pops up select Display (lower left) you should see advanced settings .. in there you will see screen orientation that should allow you to fix it
Mar 03, 2011 | Gateway 22" Widescreen Flat-Panel LCD HD...
Screen damaged from fall, colored vert lines on left side from the damge
Unfortunately the LCD panel would need to be replaced. Even if there is not any signs of damage to the outside portion of the panel, one of the inner screens may have been fractured. I am not sure if the panel would be available because if i'm not mistaken Sharp just started making replacement panels.
Apr 22, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Where you plug in the power cord the light stays on and the screen don't even turn on i need help findin the problem.
Hi There....
- Check for the brightness/ contrast of the screen
- just change the position of the screen, may be you can push it little front/ back or you move your chair a little left/ right
- check the lighting in your room and make sure direct light fall on the screen, coz you may just find the same reflection and cannot see the original screen...
- if nothing works, may be the prb with LCD screen itself and may need a repair/ replacement of the same...
ALL the Best...
Apr 11, 2009 | HP Computers & Internet
Hi, been given a dell inspiron 5150 and it wont go past the first screen. Comes up telling me that IDE device failed- incompatable cd testing and that there is a fatal system error oxoooooo8o. What the...
i think with multiple errors the best would be to contact dell technical support or you should chat with some premium engineer here
Further Queries are welcome
Feb 21, 2009 | Dell Inspiron E1505 Notebook
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Dropped TV
Hi craigaloid your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
Apr 26, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
