I have a Sandstorm S26HED12 that eventually stopped switching on.Replaced with board from eBay, now have white screen and nothing else. does it need software update?
Bought from reputable company, switches on/off OK by remote. Checked plugs and connections all OK
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
Marrie
  • 563 Answers
SOURCE: Infocus Litepro 540
Hi John
Hook up a PC and check if you get a image.
If you don't , then there is a Mainboard problem !
Posted on Mar 26, 2008
boscia
  • 163 Answers
SOURCE: husqvarna rider 155 won't start
try checking the ignition switch for any damage and replace if necessary
Posted on Nov 30, 2008
  • 3 Answers
SOURCE: Abit nf7-s rev2 not posting. Cleared CMOS, pulled
Have you tried replacing the memory modules? Memory incompatability or a bad simm, will create the symptoms, you describe. Also, restore the BIOS settings to "fail-safe," if possible. Often the "Default settings," are not as "tolerant," as fail-safe. I had a similar issue with ASUS and LanParty motherboards. It was a bad SIMM.
Posted on Mar 09, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: Roland JC-55 amp stopped working
Sounds like a transformer problem or something else in the power section..maybe even a transistor....since the LED status light would be direct from DC power. Take it to a trusted audio electronic tech and get it looked at. Keep in mind that these amps are about $150-$200 used on Ebay so don't spend too much getting it fixed if it is indeed a transformer. I'd definatley get it looked at. I have a JC-77 and it rocks for clean!
Posted on Jun 20, 2009
Hp2133 screen problem
Did you plug the lead from the motherboard in correctly or is it a faulty screen.
Feb 06, 2014 | HP 2133 Notebook
HI, i Have a 42" lg3000 lcd tv when I switch the
Hello, I have exactly the same problem with the exact same TV, white screen for about 15 minutes and than image appears perfect as if nothing happened. I have asked an ebayer which sells TV parts and he suggested it could be a main board or tcon board. I am quiet hesitant to fix my tv, but if the tcon board would fix it, i'd go for it. Did You manage to solve the problem yet?
Mar 29, 2011 | LG Televison & Video
Replaced backlight board, now screen is just white, no picture
Ur tv have only white screen with sound before?The LCD inverter board,that help for LCD screen panel to have backlight is not the problems.The tv Tuner signal board is the problems.That the board,where the incomming broadcasting signal cable wire plug into it.Repair this problems before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Jan 11, 2011 | Element Electronics ELCHW261 26 in. TV
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Hi the tv just went to a white screen..nothing..what could be the issue..
Ur tv still have sound when the screen are white?Yes?The Tuner board is dead,need it replaced.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
May 21, 2010 | Polaroid TLA-01911C TV
No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
May 11, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Lighting is a bit darker and sandstorm like/black smoke.
Ur T-con board is dead.This board is at the bottom of the tv sit right in the middle botton of the tv.Replaced this T-con board, should sholved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
Apr 27, 2010 | Televison & Video
Tv wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 25, 2010 | Samsung LN40B630 40 in. LCD TV
It just shows a blank white screen when I turn it on
Hi beans88
This is unfortunately a faulty Mainboard that will either have to be repaired or replaced.
The Part Number of this board is : 55.J8601.001 and if you decide to rather replace than repair it , you could expect to pay in the region of $125 for this part.
Thanks for using Fixya and good luck.
May 20, 2008 | BenQ PB6100 Multimedia Projector
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
