Question about Kitchen Ranges
I've had a broan cbd3 range hood for 3 yrs and it has started making a loud fan noise when its been on the High level after about 30 min. The fan turnoff button sometimes gets stuck and wont turn off.
hotuna
  • 288 Answers
SOURCE: broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Posted on Dec 23, 2007
SOURCE: Random fan speeds and light levels???
I do guarantee work for Broan & Nutone on the road. The problem with all three of your kitchen fans is the control board which is $110.00 part # R111632 for allure 3. If ever, im in Montreal,qc 1-800-363-0566 = Inventex
Jean-marc
Posted on May 14, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
Chances are you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: Wont start unless jumped or restarted within 30 mins
When trying to turn my truck on only clicking noise under hood and in dash. Sometimes even after key is pulled out clicking noise in dash continues for a couple of seconds. Battery and alternator was check at Advanced Auto parts they say both are good
Posted on Sep 27, 2008
SOURCE: Nutone WA6500 range hood fan motor noisy
We have the same product, 18 months in use and the very noisy motor has finally seized up. I contacted the manufacturer and was advised that I need a new motor, motor mounting bracket and fan rotor. The agent was not able to quote me a price for the parts but stated that even though my 1-year warranty had expired, if I faxed them a copy of the original sales reciept they could possibly send me the parts for free under the original warranty agreement. I've done as they asked but haven't received a reply as yet. After reading about all the problems with this product I'm tempted to dump the whole unit and try to find another manufacturer that has a reliable and QUIET range hood.
Posted on Jan 06, 2010
I installed a new Broan QML30SS range hood and fan makes loud humming sound as it runs
An old elecricians joke says "do you know why it hums? It dosn't know the words" Al kidding aside ,have you checked to see how free the fan blade is? The should spin very freely. It kind of sounds to me like it may be having a hard time comming up to full speed. You may try some graphite lube on the motor. If I recall Broan has a lifetime garrentee on the motor. You might just want to repace it if I am correct.
Mar 02, 2013 | Broan QML30SS Pro-Style Under-Cabinet...
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
Jan 21, 2011 | Broan-NuTone Broan Elite E661...
The fan motor makes a noise but doesn not start rotating, if you rotate the fan the motor kick in and continues to work until it os turned off.
The motor probably is not starting because the bearings are a bit stiff....
Take the hood apart and give it a good cleaning, being careful to not get the motor wet...
Then if you can get the hood in a position to run some light motor oil down the shaft and into the motor... spin the shaft as you do this... get oil worked into the motor bearings then it will probably work again...
heatman101
Jan 17, 2011 | Broan-NuTone Broan Range Hoods Rangemaster...
Hood operates very loudly
Often the dirt and grease will build up on the fan/blower wheel and then some of it will come off throwing the wheel out of balance... this creates an intense vibration of of course a lot of noise...
Take the hood apart and clean everything really good and check the motor bearing to make sure they are not bad...(loose motor shaft in and out or up and down)...
Then you should be quiet again...
heatman101
Sep 16, 2010 | Broan-NuTone Best by Broan K260A90CMSS...
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Jan 06, 2009 | Kitchen Ranges
Vibration at high speed
check these causes fan blade brackets,fan blade for cracks, any grease on blades.
Dec 27, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Broan allure II range hood
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
