Question about Sewing Machines
I have a Memory Craft 7500 and the feed dogs won't come up. I tried the lever in the back and all it does is drop further. Any help would be appreciated.
  • Sewing Machines Master
  • 12,018 Answers
Just a thought. Feed dogs generally do not raise until the handwheel is activated.
Posted on Aug 11, 2017
  • 2976 Answers
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
Posted on Jan 03, 2009
bargainbox
  • 1388 Answers
SOURCE: I lowered the feed dogs with the drop feed lever,
Flick switch to the UP position.....then....
Turn handwheel one full revolution to reset the feeddog cam
It is on page 26 of your User Manual
Bargain Box
Posted on Feb 13, 2011
SOURCE: janome memory craft 7500
the machine comes on , its on auto but the foot pedal does not make contact.
Posted on Feb 19, 2011
  • 539 Answers
SOURCE: Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Posted on Apr 07, 2012
99rannellis
  • 12018 Answers
SOURCE: How do I drop the feed dog of my memory craft 9500 machine
The feed dog release is hidden below the needle plate. You need to, first, remove the detachable extension table & accessory storage at the bottom left side of your machine.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj3gqKQiprPAhWl3YMKHbWKDuIQFgghMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fretired%2Fembroidery%2Finst-book-mc9500.pdf&usg=AFQjCNG-le_VN0TN14xsUNRpA9ylXPz26g&cad=rja
Posted on Sep 18, 2016
My feed dods have droped down how can we ajust them to raise them.
Usually when you slide the knob to drop the feed dogs they drop immediately. But when you switch the knob back to raise the feed dogs, they won't come up until you rotate the handwheel one revolution in the forward direction.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
I lowered the feed dogs with the drop feed lever, and now the feed dogs wont come back up.
Bargain Box
Feb 12, 2011 | Janome Memory Craft 10000
My feed dogs (Memory Craft 4000) won't come up after basting - which is like the emboirdery function. I too have cleaned lint from around the throat, bobbin casing, even removing the bottom plate, reset...
I have had this problem a few times, too. I have been able to get them back up by gently pushing them with my stiletto. Maybe not the best thing to do, but it worked.
Feb 01, 2011 | Janome Memory Craft 9000 Computerized...
I've forgotten how to drop the feed dogs-can you help
There is a little lever on the back of the free arm at the bottom. Push the lever to the right and that will lower the feed dog.
Jan 26, 2011 | Janome Memory Craft 3000
How do i lower the dog feed on my memorycraft 9000
there is a small lever at the back ( behind the bobbin case etc) that manually drops the feed dogs, also you can do it using the ADJ key. It should do it automatically when the embroidery mode or edit mode is pressed
Aug 07, 2010 | Janome Memory Craft 9000 Computerized...
Hi. Is there a free motion foot available for this model and can you lower the feed dogs?
Theanswer is yes and yes, you can purchase a free motion foot and there is a sliding button/lever on the back of the free arm just behind the needle plate that will lower the feed dogs, After the feed has been dropped and you want to re-engage them just flip the lever in the opposite direction and turn the machine one revolution and the feed will come back up,
Doug
Aug 06, 2010 | Janome Memory Craft 3000
Adjusting the dogs on memoery craft 9700
are you trying to drop them for embroidery ? look at the back, behind the bobbin area, there should be a lever. my 9000 also has the option to use ADJ and the grphic for the feed dogs come up. on the 9000, they disengage automatically when you go to embroidery mode. I hope this helps
Feb 01, 2010 | Janome Memory Craft 9000 Computerized...
Janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Oct 26, 2008 | Janome Memory Craft 9000 Computerized...
Janome 8000 memory craft embroidery/sewing machine
on the backside of your free arm there is a small lever which can be moved to lower the feed dogs.
When you want them back up move the lever the other way.NOTE!!
They will not go up until the machine has made one revolution.
sewman7
Jun 02, 2008 | Sewing Machines
Janome memory craft 7500
The feed dog will rise as soon as you turn the handwheel one time. Just put the fabric in it and sew. It will come up automatically as long as you have moved the lever to the correct position.
sewman7
May 15, 2008 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
42 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
