How do I load a new role of paper - Office Equipment & Supplies
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
My fd 400 credit card machine not recognizing paper
you need to make sure the paper is thermal. you can test by scraping on the paper with your nail. if a black line appears that is the thermal side and it should face down in the paper loading tray. if the paper is new try another role and or turn it over, but it has to be credit card machine thermal and not calculator paper
Jan 29, 2014 | Office Equipment & Supplies
Canon lbp 3000 laser printer is roling paper but paper coming blanck not coming any type of prints.
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
You need to purchase and install a new compatible toner for your Canon Laser Printer.
Thanking you kindly
damnor01
Feb 23, 2011 | Canon LASER SHOT LBP-3000 Printer
What is the role stepper motor in a car
That is a new one on me. Stepper motors are found on printers for industrial size computers I know of. The meaning stepper is for advancing the paper one notch at a time
Jan 23, 2010 | 2001 Land Rover Discovery Series II
The Lexmark X8350 has a hard time to feed photo paper. Is there a trick to loading through the auto loader?
well the problem might be from the printers pic up role , you might need to clean the role for it to pic up the photo paper . If you lock in to the printers auto loader opening yowl see in the back a big rubber role is positioned in the middle top of the opening , a pic up role is usually cleaned with a spray called Copy-Special but you can clean it with anything that dosent harden rubber window cleaner , maybe you can use very clean diesel fuel , ok thats just speculating use window cleaner that sould be good , you spray it onto a cloth and wipe the role clean . ooo i know use alcohol to clean it thats the best house hold material . Hope this helps .
Dec 13, 2009 | Lexmark X8350 All-In-One InkJet Printer
THe printer won't accept the paper-what to do!
Are you using the3 same brand of paper of have you changed it?
Quite often the reason the paper wont load is that the pare quaslity is too shiny or designed for photocopiers rather than printers.
INK also plays a role in this happening. Look at thew rollers and see how much ink is on them, clean off with Isopropyl alcohol. Use some on the pare guides as well These are the wheels in front of the paper loading area
Hower,m either get the same brand of paper you had originally or try some differenet paper suitable for printers.
Please rate our help to keep the service online++++Thanks for using FIXYA
Sep 21, 2009 | Canon Pixma MP480 All-In-One InkJet...
Cash register will not accept new role of paper, when trying to fix it I must of hit something now the roller won't spin and 'error 94' pops up.
For Casio 110/120/130CR E94 = Printer Problem
Normally there are something "stuck" inside the printer or paper feed assy spoilt.
Jul 10, 2009 | Casio Parts Cash Register PC Desktop
MP150 Can't load the Paper
I BELIEVE MY PROBLEM IS THE SAME. MP 150 WILL NOT PRINT. IT REPORTS ERROR E 3 PAPER JAM. THERE IS NO PAPER JAM. I HAVE HAD SEVERAL COMPUTER KNOWLEDGEABLE PEOPLE LOOK AT THIS AND THEY SAY IT'S A MECHANICAL DEFECT. I CALLED CANON TECH AND SPENT OVER AN HOUR WITH THEM TRYING TO CORRECT THE PROBLEM. ESSENTIALLY WHAT THEY HAD ME DO IS TO UNINSTALL THEN REINSTALL THE DRIVER SEVERAL TIMES. STILL DID NOT FEED.CANON FIRST SAID THEY WOULD REPLACE UNIT N/C BUT......... I RECEIVED SAME AS A GIFT ON 12/15/07 SO DO NOT HAVE RECEIPT. THE DONOR HAS HIS AX RECORD OF PURCHASE IN DECEMBER 2006 BUT NOT THE ACTUAL SALES SLIP. CANON THEN SAID TOUGH LUCK BUT I CAN SEND IT IN TO THEIR REPAIR CENTER AND WILL BE CHARGED FOR REPAIR UP TO $40 OR TAKE A REFURBISHED UNIT INSTEAD. I FOUGHT THIS SO HARD BECAUSE I JUST BOUGHT AND HAVE ON HAND FOUR NEW INK CARTRIDGES THAT COST $70 THAT I CAN' T TAKE BACK TO OFFICE STORE FOR CREDIT. MY SUGGESTION IS TO UNINSTALL AND REINSTALL PRINTER DRIVE. IF THAT DOES NOT WORK, BUY AN HP REPLACEMENT AS I WILL DO. NO MORE CANON FOR ME....
EX CANON CUSTOMER
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How to refill my paper in the fax machine
i am new user and dont have manual so how to operate magic 3-2
Apr 22, 2007 | Philips PPF-531 Plain Paper Thermal...
k24674
jasbo
jasbo
