Question about In Office Equipment & Supplies
Feed in new role of paper tape - In Office Equipment & Supplies
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
I don't know how to put my paper in it.
After hanging the paper role in its position, insert the edge from behind and press feed, continue until the edge is out on the opposite side.
Feb 03, 2010 | Canon P23-DHV Calculator
The Lexmark X8350 has a hard time to feed photo paper. Is there a trick to loading through the auto loader?
well the problem might be from the printers pic up role , you might need to clean the role for it to pic up the photo paper . If you lock in to the printers auto loader opening yowl see in the back a big rubber role is positioned in the middle top of the opening , a pic up role is usually cleaned with a spray called Copy-Special but you can clean it with anything that dosent harden rubber window cleaner , maybe you can use very clean diesel fuel , ok thats just speculating use window cleaner that sould be good , you spray it onto a cloth and wipe the role clean . ooo i know use alcohol to clean it thats the best house hold material . Hope this helps .
Dec 13, 2009 | Lexmark X8350 All-In-One InkJet Printer
Cash register will not accept new role of paper, when trying to fix it I must of hit something now the roller won't spin and 'error 94' pops up.
For Casio 110/120/130CR E94 = Printer Problem
Normally there are something "stuck" inside the printer or paper feed assy spoilt.
Jul 10, 2009 | Casio Parts Cash Register PC Desktop
Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Register tape
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 13, 2008 | Sharp EL-2192Rll Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Oct 11, 2007 | Office Equipment & Supplies
How to refill my paper in the fax machine
i am new user and dont have manual so how to operate magic 3-2
Apr 22, 2007 | Philips PPF-531 Plain Paper Thermal...
Top In Office Equipment & Supplies Experts
Mohul
Mohul
Level 1 Expert
Tygh Duval
Tygh Duval
Jason
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
