Question about Ovens
I am not an electrical person at all. How can I be sure that I need to replace a spark module? Where can I buy it?
2 Suggested Answers
  • 572 Answers
SOURCE: Remove and Replace Clock Module
at any appliance store
Posted on Feb 11, 2010
Power cuts out 5 minutes after oven is lit
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 10, 2015 | Ovens
Electric wall double oven no power, no display, nothing works, breaker not tripped. What is the problem?
GAS OVENS
Aug 04, 2014 | Ovens
Zanussi gas cooker gas not coming through no ignition
GAS OVENS
Jul 30, 2014 | Zanussi Ovens
Why won't my gas grill stay lit?
Oven clicks as if it is relighting almost constantly.
Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
GAS OVENS
ELECTRIC OVENS:
Jul 04, 2014 | Zanussi Ovens
I have a whirlpool gas oven model # SF367LEKB and the oven will not ignite. You can not hear a clicking sound and the ignitor is not sparking
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good!
GAS OVENS
Apr 30, 2014 | Whirlpool Ovens
There is no gas flow to one of the ovens igniters
GAS OVENS
Jan 28, 2014 | Viking 30" Professional Select Built-in...
Oven not working
GAS OVENS
Nov 22, 2013 | Belling Ovens
Diplomat adp 0511 grill has no gas or ignition
GAS OVENS
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Ignitor on Frigidaire model PLCS389DCC is not working. How can I replace it.
There are a couple of ways you can resolve this issue, depending on what isn't working. As it's difficult to determine by the brief description of the problem you're having, I can't tell if the main spark (ignitor) module is the faulty component, or if you need to replace a specific ignitor/orrifice assembly for one or more burners.
If none of the top surface burners are lighting when you turn them on, it is most likely the spark module that needs to be replaced. If it's only one burner that is not lighting, then you'll need to replace that burner's ignitor/orrifice assembly.
To get at these components, all you need to do is lift up the top range surface to expose the burner assemblies and the spark module. Be sure to turn off the gas line and unplug the range from the electric outlet to prevent any shock hazard, etc. Removal and replacement can be done with simple hand tools and by simply unplugging the electrical plug on the spark module.
Here's a exploded line drawing showing the components, part numbers, and a price list as well. You can order the part(s) needed online as well.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PLCS389DCC&productCategoryId=0122008&brandId=1428&modelName=DUAL-FUEL-RANGE&diagramPageId=00002&componentDescription=BURNER&documentId=R0504191&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
