Question about Cell Phones
How do I find the numbers I blocked - Cell Phones
How to block numbers
To block calls, open the Phone app, select Call History, tap the number, then select Block Contact or BlockCaller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.26 Sep 2016
How to Block a Number on Any Phone '
or go to this link for other phones. How to block numbers Google Search
Oct 28, 2017 | Cell Phones
Chevy engine block identification numbers V0710FSC TEJ528846
Small Block Chevy Engine Block casting and code identification
Sep 14, 2012 - Small Block Chevy engine identification. Code identification, Casting Number info.
Chevy Casting Number identification - Block casting numbers Chevy Casting Number identification including Block casting numbers, cylinder ... 2-bolt Chevy II Nova Recessed filter .... 2 & 4-Bolt Mexico cast Crate engine.
Reference: Chevy Engine Block Casting Numbers - Chevy ******** Sep 19, 2013 - The engine block casting number for both BBC and SBC engines is found at the back of the block where the transmission mounts to the engine.
Chevy Identification Numbers - If you have a small block Chevy engine, and need to identify any parts you have laying around, or maybe the engine that is in your truck, I think you will find the ...
Chevrolet - Browse - Casting Numbers .info: engine blocks, heads ... 12562932, Category: Cylinder Heads Type: Big Block V8 Date: 1991-1995. Notes: oval port, open chamber, Gen.V, truck crate motor, 118cc chambers gm chevy ...
Jul 04, 2017 | Cars & Trucks
Can you block a number from calling you on the LG Octane itself.
You can log onto your Verizon account, go to "Block Calls & Messages" and enter the 10 digit number you want to block. You can block up to 5 numbers at no charge, but it only blocks those calls for 3 months, then you have to go in and enter those numbers again. If you want to block more than 5 numbers you must subscribe to their Usage Controls program. To un-block a number, simply hi-light and delete the number from the blocked numbers list. Hope this helps.
May 11, 2011 | Cell Phones
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
I want to block this cellphone number in smart, +639185572926
hello po.. puede po ba i block i2ng number na ito 09198708504.. scammer po kasi ito ehh
Oct 15, 2009 | Nokia Consumer Headset
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
Jan 13, 2009 | Uniden Cordless Phone
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Jun 30, 2008 | Sprint PCS Phone SCP-2400 by Sanyo(r)...
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
