Question about Refrigerators
The defrost tube is stopped up, but how do you get into it to unstop it?
4 Suggested Answers
dcp2
  • 63 Answers
SOURCE: freezing drain tube
Sometimes what causes this is a obstruction in the drain line. It may be draining, but not fast enough. the water could still be backed up enough to freeze after the defrost cycle. I would clean the line out with compressed air, or flushing water down it. If there is no progress with this, then you can get a drain line defrost heater. they come in all sizes, voltage, and Watts. You should be able to wire it directly into the defrost circuit
Posted on Jan 28, 2008
  • 69 Answers
SOURCE: moon roof leaking tube in corner stopped up.
If you can access the top side of the tube without removing the moon roof, you can take an air compressor hose with a rubber nozzle, jam the tip in the hose and blast it with quick bursts of air. To insure that you got the blockage out, pour some water in that area and watch around the wheel well for the water to flow out.
Posted on May 27, 2009
heatman101
  • 43501 Answers
SOURCE: the defrost drain is stopped
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 28, 2010
The defrost drain is stopped up. how do you unstop it?
heatman101
Nov 27, 2010 | KitchenAid Refrigerators
Air conditioner drain is stopped up and running into car floor how do i unstop drain
on your firewall of your van neer where the a/c lines go through the firewall there should be a plastic tube there i would try something soft like a soft drink straw so you dont damage the condensor if you have room put a shop vac up to it
Jun 29, 2010 | 1999 Oldsmobile Silhouette
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Moon roof leaking tube in corner stopped up.
May 27, 2009 | 2006 Land Rover LR3
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
Condensate Leaking
sounds like a stopped up drain tube. probably will need to take to repair facility so they can use compressed air in drain tube to unstop it. Hope this helps.
Sep 10, 2008 | 2004 Mitsubishi Galant
REFRIGERATOR dRAIN stopped up
SOME REFRIGERATORS HAVE A CUP IN THE BACK OF THE FRESH FOOD COMPARTMENT THAT CATCHES THE WATER AS IT COMES FROM THE FREEZER AND SENDS IT DOWN THE DRAIN TUBE INTO THE DRAIN PAN. IF THE DRAIN TUBE OR CUP GETS A RESTRICTION IN IT, IT WILL OVERFLOW AND BRING WATER INTO THE REFRIGERATOR. CHECK THE CUP AND DRAIN TUBE FOR RESTRICTION.
SOME REFRIGERATORS HAVE THE DRAIN TUBE BUILTIN TO THE WALLS OF THE REFRIGERATOR, BUT THE HOLE IN THE FREEZER IS SMALL AND FREEZES OVER. WHEN THE DEFROST CYCLE COMES ON, THERE IS A BUILDUP OF ICE THAT CAUSES THE WATER TO FALL DOWN THROUGH THE AIR DUCT INTO THE FRESH FOOD COMPARTMENT. YOU WILL HAVE TO REMOVE THE BACK WALL OF THE FREEZER AND SEE IF AN ICE BUILDUP UNDER THE COILS IS PRESENT. THEN, REMOVE THE ICE, CLEAR THE DRAIN HOLE, AND SEE IF WATER WILL PASS THROUGH THE DRAIN. A FIX TO PREVENT FREEZEOVER FROM REOCCURING, IS TAKE A PIECE OF BARE COPPER WIRE AND WRAP AROUND THE DEFROST HEATER AND PASS IT DOWN THE DRAIN HOLE (ABOUT FIVE INCHES WILL DO).
WHEN THE DEFROST HEATER COMES ON, IT WILL PASS HEAT DOWN THE WIRE TO KEEP THE DRAIN HOLE FROM FREEZING UP.
Apr 16, 2008 | Refrigerators
Freezing drain tube
Jan 13, 2008 | Freezers
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
