When I try to set our TV to locate digital channels, the menu skips the channel selection when I scroll through options of picture, audio, channel, lock, setup. All the options are available.
    President:
  • 563 Answers
It sounds like your TV is on a different input. If you watch your cable from an external cable box, and this box is plugged into your TV using wires that are yellow, red, and white, or red, blue, green, red and white, you're currently watching TV on a different input than the one used for the antenna. Channels in a TV are controlled by the tuner. The tuner is the silver, threaded, post on the back of a TV, DVR, converter box, or VCR, that you plug an antenna or cable wire to. The tuner contols channels while the other inputs on your TV carry a direct signal like a computer to a monitor. So when you use something other than coaxial cable to connect cable to your TV, you can't access the channel menu while on that input. To access that menu, change the TV's input or source to TV or stop when you see a channel number on the screen. You have to be on the TV or tuner input in order to access the channel menu. If you're on any other input such as, S-Video, AV1, AV2, component (Yp Br Cr), HDMI, etc. you will not be able to do a channel scan. You have to be on the right input or source.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 27, 2009
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
Toshiba LCD TV/DVD 15LV505 lost channels. Rescan = fewer channels. Now in Setup, when I press the remote down-it skips the Channel option. What must I fix/change in Settings to get the Channel option?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Dec 08, 2016 | Toshiba Televison & Video
Just switched to digital in Denmark & lost my channels.What can I do?
look at the input devices in main menu .you might have to select cable as input
Feb 11, 2016 | Televison & Video
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have lost channels 5,itv 3,and itv 4,and do not know how to retune my tv, all other channels appear to be alright slightly confused when i press the menu button and not know which links to follow?
All Freeview channels need re-tuned after 30th September.
To re-tune your Sony TV...
1.Press Menu button then go to settings...
2.Scroll down the menu icons until you get to 'Digital Set-up'
3.Press enter/centre key next to direction arrows
4. Select spanner icon and digital audio tuning.
5. You will then be asked if you want to start digital audio tuning.
6. Press enter/centre button....and thats it!.... TV will automatically re-tune.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Cannot tune in programmes I go to menu which brings up screen picture, audio, time but skips on tuning into progs and goes to options. Please help.
Select TV as input source by TV remote or push Channel button on remote then go to TV Menu. That will enable Tuning menu in TV.
Jul 28, 2009 | Televison & Video
I have GE XS Stereo Commercial Skip Model 27GT619
  1. On the front of the TV press the MENU button to display the MAIN MENU.
  2. Scroll through the choices using the VOLUME up and down buttons
  3. When positioned on the selection you want press the MENU button again.
  4. The first SETUP screen displays, asking you to select a language.
  5. Scroll to the desired language ENGLISH, FRANCAIS or ESPANOL and once it is highlighted in green press the MENU button to make finale selection.
  6. A SETUP screen appears asking if you would like the TV to search for all channel
  7. 1. Yes
    2. Skip this step
    3. 0 Exit
  8. Complete the SETUP routine or skip any of the steps and return to them later.
This information is from the User Guide that came with our set. Good Luck.
Jun 11, 2009 | GE 27GT271 TV
Channel search: skips chanels
If you have a cable box connected, it's synch circuits are bad. If your TV has a selection for HRC/ IRC make sure you know which one cable company is using .
Apr 15, 2017 | Polaroid FLM-1911 19 in. LCD Television
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
Electro Med Services...
