Question about Giant Cycling
What year was a giant cypress bike serial number 6s762902 made
  • Giant Master
  • 1,176 Answers
Google "Giant serial number" to see if a database is available. If not see my tip for other options. BUT generally year, model is not that important. How to determine the year value etc of your bicycle
Posted on Aug 11, 2017
  • 89 Answers
SOURCE: year for a older dirt bike
go to the website of what type of bike it is.they should be able to help or contact a dealer.
Posted on Mar 26, 2009
ckoira57
  • 267 Answers
SOURCE: serial number problems 1t0-003815
It is a YZ80D 1977...first link below is a Yamaha VIN cross reference if you want to verify. (a lot of scrolling)
As your VIN is only 9 digits, this indicates a pre 1982, when a universal 13 digit VIN was adopted, then soon after our current 17 digit VIN.
(please note: I'm assuming the VIN is from the plate on frame and not the crankcase serial number as engines are easily swapped)
Second link appeared amongst a search and indicates a 1992 model. This may be the basis of the problem your encountering.
Third link is a Yamaha decoder I've used successfully (17#) try it or check the Yamaha Corp. link therein.
Cheers.
http://www.johnnystoybox.com/yamaha_parts_cross-reference.htm
http://www.boats.net/parts/search/Yamaha/Motorcycle/1992/YZ80D/parts.html
http://www.motoverse.com/tools/vin/yamaha.asp
Posted on May 18, 2010
  • 21 Answers
SOURCE: cna't remove front wheel from my giant cypress bicycle
your wheel is either held on by a nut on either side of the fork or a quick release. In the case of the nut, you simply loosen both sides using a wrench and then the wheel will come off (the axle may have rusted to the fork so you may need to "persuade" it a bit with a rubber mallet). If you have a quick release, you unlock the release lever by pulling it towards you...you may also need to then unscrew the nut on the other side before the wheel will release.
Posted on May 25, 2010
  • 16 Answers
SOURCE: Boulder 3 Mountain Bike..location of serial number
Serial Numbers are usually in one of two locations.
  1. Turn the bike upside down and look at what is the very bottom of the frame where the pedals and cranks pass through. This is the bottom bracket shell. Serial numbers are commonly stamped here and will be a long series of numbers and letters
  2. Occasionally they are also stamped inside the rear dropout on the left or right. The rear dropout is the part of the frame where the rear wheel is connected.
Matt @ roadragecycling.com
Posted on Oct 19, 2012
  • 48497 Answers
SOURCE: Giant Cypress DX. How do i remove the front tire?
unthread the axle bolt on both sides and lift it off the frame .
Posted on Apr 18, 2016
I am trying to determine a bike model by the serial # GK7A047. It appears to be a Giant brand but neeed to know the year, model and stock components
Aug 10, 2017 | Giant Cycling
Elwood Se giant bike 26 inch brake serial number needed
DOES NOT EXIST, NOT NEEDED. Just replace with a similar type of brake caliper.
Jun 05, 2017 | Giant Cycling
Giant Advanced Anthem X, Serial # GK4D453, What year
Go to BikePedia, enter make and model, then browse through until you see your bike's color scheme, check against components to confirm.
May 15, 2016 | Giant Anthem X Advanced SL 1
How can I tell what year my Giant Cypress DX bike is?
Made from 2009 to 2014. Have to ID by paint scheme, equipment, decals. Search model at BikePedia
Mar 19, 2016 | Giant Cycling
How do i find year if all i have is serial number.
Bike serial numbers - Bike Index
https://bikeindex.org/serials
All bikes all have unique serial numbers. ... Hopefully you can find the serial numberon the bicycle you're looking at, Contact us if you're having trouble. Okay ...
What bike serial numbers are - and where to find them. ... All bikes all have uniqueserial numbers. Most bicycles have their serial number engraved beneath ..
How to Read and Check Your Motorcycle or ATV VIN ...
www.motosport.com/.../how-to-read-and-check-your-motorcycle-or-atv-...
Jul 10, 2014 - The Vehicle Identification Number or VIN of your motorcycle, dirt bike or... The VIN contains information on the manufacture, model year and where it was built.... to find exactly what you need and quite often a sales rep will ask for it. ... dirt bikeor ATV the VIN tells you or a prospective buyer if the bike has ...
Jan 05, 2016 | Motorcycles
Oct 17, 2012 | Giant Bicycle Inc. Cycling
Creaking noise from handlebar stem on giant cypress bike
Hi Martin, I would suggest you ask them to check your headset as well, that could also cause the noise.
But if it is the stem, get some carbon paste from a shop and loosen your stem yourself, apply the paste thinly to all surfaces that makes contact and tighten it again.
That should keep it quiet, but something else to keep in mind, don't ever use high pressure cleaning equipment on your bike!
Dec 20, 2011 | Giant Cycling
Hi i have brought a giant ds3 warp bicycle off a friend and would like to know how i can find out more about it. i have the serial numbers but i cant seem to find a site that will direct me to search the...
theres not alot to know about it pinkbike.com could have an article about it or just the giant website its an older lower end full suspension bike and they also had faulty rear pivot bearings if its not squeaking now it will be soon
Dec 21, 2010 | Cycling
Cycling Logo
63 people viewed this question
Top Giant Cycling Experts
John Egan
John Egan
Andrew Taylor
Andrew Taylor
dante
Are you a Giant Cycling Expert? Answer questions, earn points and help others
