Question about Refrigerators
How do you get to the drain hose? Thru the freezer part or refrig. part
  • 90 Answers
SOURCE: Fridg
water line in freezer door is froze up. Call GE customer service to see if your ref. has a service bulletin.
Posted on Jan 05, 2008
  • 146 Answers
SOURCE: freezer leaking into refrig compartment how do i
You shuold have a schematics with your refrigerator, used by service people it can help you locate the drain - There are 2 different areas depending on your refrigerator - on some older models there is a drain hole behind the back panel of your freezer - what from the defrost cycle drips into the hole which goes through the ceiling of your refrigerator at the back and into a drip cup - this cup is connected with a tube through a hole at the back of your refrgierator wall and into the drain tube that goes down into the drip pan at the bottom of your refrigerator (this usually sits ontop of the compressor and can be removed. You can see th is tube coming out of your refrigerator if you look at the back, usually they are behind the condenser coils - if you are able to remove the drip cup in the refrigerator you can unplug the line, maybe it is clogged with debris or even plugged with ice - you can use a fairly long piece of pipe cleaner and see if you can unclog it - do the same for the drain hole behind the back panel in your freezer ! On newer refrigerators with enclosed condensers, the drain tube is also enclosed and less likely to leak - but you can access those by removing the panel, it is always behind the panel in the freezer right under the cooling coils and defrost element - make sure you turn off your refrigerator and unplug it before cleaning - be careful not to bend or break anything with sharp objects - with fridges without a drip cup inside, it is rare to get leaks - as the hole at the back of the freezer is TILTED so water will drip to the back and into the tube, that tilted drain connected to the hose is behind the vent to the fridge - it would take a serious clog or ice formation to leak so I will assume you have a drip cup in your fridge that is overflowing and leaking at the back of your fridge inside.
With some refrigerators the drip pan at the bottom is sealed to the base, you will notice a hose going down on it and a big fan blowing hot air from the compressor - Check the drip pan at the bottom exterior to see if it is overflowing with water - normally it should be evaporating with the heat of the compressor - these type of problems are rare. Inside the fridge with drip cups it can be common - simply clean the line of any debris and that will solve your problem.
There can also be other causes of water leaks to your refrigerator, but the most common is a plugged up defrost line.
I hope this helps.
Newer refrigerators with enclosed condensers
Posted on Aug 22, 2009
terrencio
  • 20 Answers
SOURCE: the water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Posted on Sep 26, 2009
  • 674 Answers
SOURCE: Water is leaking on the floor. Drain pan is dry.
Do you have an ice maker feature. If so check the water line to the back of the refrigerator. It may be leaking.
Posted on May 03, 2010
TheMobilian
  • 8220 Answers
SOURCE: Water is collecting on top
Most times the water might be from defrost liquid pooling up from a clogged drain hole but it might be from bad door seal OR dirty condenser. Try and clean out the condenser area where the air flow will be at its maximum and raise the legs lightly in front to throw the weight of the doors towards the rear of the box to make them close their seals tighter.
GE bottom Mount Service Manual
Posted on Feb 04, 2011
My freezer keeps leaking wated
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Sep 27, 2010 | Refrigerators
How do I access freezer drain to unclog, clean out?
its easier to blow/syringe it backwards from the drip tray.use neat clorine bleach.
Aug 24, 2010 | Frigidaire FRT18G5A Top Freezer...
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Leaking water from the freezer to the fridge
Apr 09, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking down from freezer
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER , solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Dec 09, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water in my refrigerator
The defrost drain is stopped up, or frozen up. You will need to turn the refrig. off defrost the drain. This can take time. Locate the drain hole in the center of the back of freezer. You will need to remove the back panel. The fastest way is to find a bottle with a plastic tube about 1/4 in attached and fill the bottle with HOT water and squeeze it into the drain
Nov 18, 2009 | Frigidaire FRT15B3A Top Freezer...
The water is overflowing from the freezer onto refrig shelf
Sep 26, 2009 | GE Profile Arctica Stainless Steel Top...
GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW VEG. BINS, HEAVY CONDENSATION ON WALLS OF REFRIG. CANT FIND A DRAIN HOLE AT BASE OF FREEZER OR FRIG.
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Aug 02, 2009 | GE Refrigerators
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Fridg
Jan 05, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
