Question about Hoover Washing Machines
I have a hoover dxt58h/1-aus washer.it displays e13.Ive already check the heater&thermostat-they're fine. I don't know if its board.Is there a reset for that type of washer?
steve6375
  • 395 Answers
SOURCE: ''CMOS Settings Wrong! USB DEVICE OVER CURRENT STATUS DETECTED
Have you checked all USB port sockets to see if any of them are broken? I mean inside the socket itself. It is easy to break the small plastic black tongue in these (e.g. by bending down on a USB memory stick. Then when you put another USB plug into it, the 4 contacts can get bent and the +5V will short out with the case.
Check all USB sockets.
Posted on Nov 16, 2008
pontelemon
  • 538 Answers
SOURCE: it displays D : 1 E13 1E12 on the screen
Shutter flex bad/worked itself out.
Available as a whole Lens Block only.
Posted on Mar 20, 2009
  • 279 Answers
SOURCE: Why all the compartments of our fridge was frozen, then the control sensor the red light keep flashing and beeping?
Check your defrost heater element again, if ok change control module.
Posted on Dec 20, 2011
  • 574 Answers
SOURCE: Frigidaire affinity front load dryer e61 code. Replaced the control board and display board. Still have the same problem e61. How do you check heater relays?
ther is a thermocouple next to heater elements , check continuity of elements and thermocouple
Posted on Mar 22, 2012
FitzOriginal
  • 842 Answers
SOURCE: Hoover washer dryer wd 9616c error code e13 and burning smell from the rear????
The automatically suggestted E13 guidance that the system posts referring to Bosch machines is irrelevant I'm afraid. On a Hoover, the message means "Faulty module connections. Check all connections between modules and associated wiring." The chances are that you have a partially dislodged connector on the main board, or on the connector that goes to the motor
Posted on Oct 14, 2015
Oct 14, 2015 | Hoover Washing Machines
How can I fix my washer when it stops with an E13
E13 indicates your input voltage is to high
also can happen with faulty motor/ brushes
Jan 31, 2015 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hoover e13
you may have some loose wiring or wire connections that have corrodied and aren't making good contact-unplug and plug back in the wires between the control board and the display board-hope this helped-cheers Denny
Oct 21, 2013 | Washing Machines
E13
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
Here the tips... support/t7599677-error_code_13
Apr 25, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a toyostove laser 30 kerosine heater which was displaying an EE 8 message, a repairman came and replaced the blower moto, and it started running agina, but now is showing an EE 13 message which the...
EE13 is for the burner thermister, not the thermostat. It prevents the burner from overheating. It does not reset after it has opened an will need to be replaced. Perform a resistance check on the thermistor. It should be less than 200k ohms after preheating. If it isn't, replace the thermistor. If it is the problem could be the circuit board. Hope this helps. Let me know if you need more assistance. nitensheaterservice@earthlink.net
Oct 26, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Dryer not working
thermostat on top of dryer heater may need to be reset . Unplug and remove top and just push gently the thermostat (red) you may hear it click .now reset or perhaps a lead as broken to the dryer heater .
Jun 28, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
49 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
