Question about Dishwashers
Essential dishwasher. All the lights flash & cannot select a wash program.
  • 641 Answers
SOURCE: Lights flash but wont start
If the dishwasher is still under warranty, best thing will be to conntact for manufacturer service !! The problem you describe could be cause off : * A Defective switch level that doesn't "shows" that there is enough water in the dishwather and therefore will prevent program's advance. * A defective heater- If water will not reach need temperature it will prevent program's advance as well. * Defective timer - Dishwasher's heart. In case your washer is over its warranty period and you would like to solve your problem by yourself, let me know and I will instruct you step by step how to to find the defective part and how to fix it. Good luck !
Posted on Jun 09, 2006
SOURCE: dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Posted on Aug 22, 2008
SOURCE: Smeg Dishwasher STA945.1, flashing lights
have you check the pipe's for blockage
Posted on Sep 11, 2008
  • 530 Answers
SOURCE: Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Posted on Jan 06, 2009
aborcass
  • 2651 Answers
SOURCE: Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Posted on Jan 10, 2009
Is there a reset button on frigidaire dishwasher model fdb710lcb0
Mate im in Australia and don't know if the Frigidaite is the same as the Electrolux/Westinghouse but you can try this I posted a day ago:
On the Westinghouse and Electrolux dishwashers to reset a program that it defaults too you start the program and once initialised then press and hold the program button for about 3-5 secs. The panel will beep and all the lights will come on and not flash. From there on using the program button you select the wash cycle you want
May 28, 2016 | Frigidaire Dishwashers
How do i reset the consol?
already answered as solution to another question by you.
May 03, 2014 | Westinghouse Dishwashers
When I turn on the dishwasher, the light on program 6 flashes but the program will not start.
Pull the power plug or turn off the circuit breaker for about 30 seconds, plug it back in or turn the breaker on and the diswasher brain should have reset. Good Luck.
Dec 14, 2017 | Smeg 24 in. DWI612 Built-in Dishwasher
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Jun 09, 2006 | Frigidaire 24 in. GLD2250RD Built-in...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
