Question about Hoover Vacuums
Hoover U5070-930. I need to replace the e belt that drives the belt it off the bottom covering the works to replace the belt
  • Hoover Master
  • 1,503 Answers
I don't understand what you are asking
Posted on Sep 22, 2017
informatica
  • 1114 Answers
SOURCE: need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 28, 2007
reddevil6
  • 1673 Answers
SOURCE: NEED TO REPLACE DRIVE BELT
Take off the brush roll cover, then take out the screws from the bottom to remove the top lid, the belt goes from the brush roll to the motor shaft.
Posted on Apr 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
SOURCE: How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Posted on Feb 02, 2009
  • 294 Answers
SOURCE: hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Posted on Apr 21, 2010
How to replace belt on hoover SH40060
You have to remove the roller to get to the belt' look at the face and bottom to find the screws that hold the plate that covers the roller. Take the plate off and look @ the roller, to see where the belt runs. then take the roller out, you should be able to see the pin shaft that comes from the motor,the belt goes around it and over the roller.Be patient putting it all back together,and don't over tighten the screws, they strip easily, Good luck!
Feb 20, 2015 | Hoover Vacuums
Beater bar isn't working
Sounds like a broken belt. Unplug it flip it over and look at the bottom there is a cover over the bottom and the beater bars look for screws or levers to remove the cover then replace the belt. it goes around the beater bar and a drive shaft. check HERE for a manual and belts.
Jun 23, 2011 | Hoover Company Wind Tunnel U53019 Upright...
Hoover empower belt need replace
Apr 18, 2010 | Vacuums
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site hoover.com
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
May 20, 2008 | Vacuums
NEED TO REPLACE DRIVE BELT ON HOOVER VACUUM MODEL TURBO 3500
Apr 17, 2008 | Vacuums
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Replace the belt
on the bottom there is a few screws remove cover and there is a roller brush there and the rest should be self explanitory
Oct 16, 2007 | Hoover U5227-930 Elite Upright Vacuum
Vacuums Logo
56 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
