Question about Dishwashers
My dishwasher is not draining. I think something is stopping it up. Where do I look?
  • 62 Answers
Normally the drain for the dishwasher runs behind the cabinets and ties into the sink drain, just above the trap. So if the dishwasher is near your sink, check there, usually it is a rubber joint there with a hose clamp. Have a bucket ready just in case it is backed up and dumps water, then remove the hose clamp and twist and pull the hose off and check it. If there's no blockage there, then it's most likely the pump went bad in the dishwasher itself.
Posted on Aug 11, 2017
Samsung dishwasher starts and after while stops with three lights cycles on (heavy , normal and quick)
I think that light combination means "Drain error". Most comonnly caused by something hard getting down into the drain pump, blocking or partially blocking the drain pump impeller or the check valve inside the drain hose right next to the drain pump.
Feb 24, 2015 | Samsung Dishwashers
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Dishwasher will not drain I think it:s the pump
It will help if you provide the make and model of dishwasher. There can be several reasons for dishwasher not draining. The most common is blocked filters or drain hose. Also ensure the kitchen side of drain is clear. If pump is running but making grinding sounds then something is blocking the drain pump. If you do not hear pump running sound then the dishwasher may not even be getting to the drain cycle for other reasons.
Apr 19, 2013 | Dishwashers
Dishwasher won't drain
There could be something blocking the drain. Perhaps some food or something else. You might need someone to take it apart to clean it out if you aren't able to do it yourself. I think it is under the dishwasher behind the lower panel.
Feb 26, 2011 | KitchenAid 24 in. KUDS25SH Built-in...
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Jul 29, 2010 | Dishwashers
Power Light on but will not start cycle
Usually Whirlpool dishwashers have a reset code which is pushing the buttons on your dishwasher such as push heat dry, then normal, then heat dry, then normal, within 5 seconds - so push them fast and in that order and wait. It may take a couple of minutes but should reset. If that isn't it, it may be the pump motor not working properly. Also look down into the bottom of the dishwasher and make sure something isn't stuck down into the drain such as a broken piece of glass or a fork. Is there water still in the bottom? It may not be draining so that would suggest it is stopped up. It could be the keyboard but showing power it seems less likely. I don't think it would be the thermal fuse because that usually stops everything including the power light.
Apr 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
Top Dishwashers Experts
