Question about Miscellaneous
Chole, where is she
Was skilled off
  • Miscellaneous Master
  • 2,131 Answers
Posted on Aug 15, 2017
  • Don A
    Don A Aug 15, 2017
    See season 4 of Smallville.
What is the name of ----Campbell
Neve
Canadian eh?
Neve Campbell - IMDb
www.imdb.com/name/nm0000117/Neve Campbell was born and raised in Guelph, Ontario, to Marnie (Neve), a Dutch-born psychologist and yoga instructor (from ... Campbell first came to our TV screens in the hit Drama series Party of Five (1994). ... Alternate Names: Chole ..
Neve Campbell Google Search
Jul 11, 2017 | Air Tools & Compressors
CRAFTSMAN 2-CYCLE TRIMMER MODEL NO. 316.711190 WILL START BUT WILL NOT RUN UNLESS CHOLE IS ON.
OK, lets slow down a bit. First look at the primer bulb of the carb. Depending on the type, there should be 2 or 4 screws right by the primer bubble. Carefully, remove the screws. The top section with the bubble and one fuel line will come off. In between them is a gasket and diaphragm. Look at the lower half and you will see a very small screen. Get some carb cleaner and spray by the screen but not too close. This is where most of the dirt collects. You might need to remove dirt by hand. Then close the carb. back up. Place gas in the tank, but leave the cap off, so you can look inside while you press the bubble slowly. You should be able to watch gas flowing back into the tank at a steady stream. Then place cap on and follow the start up instructions. Get back to me when you can.
Apr 01, 2014 | Craftsman 25cc Gas Line Trimmer
1998 GSXR 600 Choke leaver will not move. Do I need to replace the cable or can I simply adjust, lube or tweak my current cable?
Two things, it could be the cable that has jammed between inner and outer. Remove the cable from the system and check it if it does work.( the cable should move freely with out much of resistance) if not than it has to be realeased or replaced.
If the cable does run freely than there is a problem at the carburator chole linkage, check that out too.
Oct 05, 2013 | 1993 Suzuki VS 800 Intruder
High idle problem on 2001 toyota corolla
TRY THE KNOB LOCATED ON THE CARBURETTOR TOP WHICH INCREASE OR REDUCE THE ENGINE RPM.OR CHECK FOR ECCELATOR WIRE THAT MIGHT HAVE GONE STUCK. ALSO SEE THE HALF ROUND ROCKER WHICH IS TURNED WITH THE ECCELATOR LOCATED ON THE ENGINE TOP (CARBURETTOR) HOPE IT DID NOT GOT STUCK CHECK IT MOVEMENT. OTHER REASON COULD BE THE CHOKE THAT GOT ENGAGED AND COT COMING BACK IF IT IS AUTO CHOKE OR IF THE CHOLE IS MANUAL SEE THE PULL KNOB NEAR THE STEERING IF IT IS PULLED OUT HAS TO BE PUSHED IN. ENGINE EXCEED ITS RPM WITH THE CHOKE APPLIED. I DO NOT KNOW WHICH TYPE OF CHOKE YOUR TOYOTA IS USING.
JUST FOUND ENGINE MANUAL/REPAIR PDF FILE THAT MAY HELP YOU PLEASE SAVE A COPY FROM THE SITE.
http://celica.nfv.ee/manuals/2ZZ-GE_repair_manual.pdf
Aug 31, 2012 | 2001 Toyota Corolla
1986 misan 300z car will ot idle when first starts
Check that the choke is not stuck open or not working at all. THe chole has an accelerated idle cam which increases the idle speed when the engine is cold and the choke is supposed to be closed and as it starts to open.
Jul 08, 2011 | 1986 Nissan 300ZX
Cant remember how to start my g100 wacker. Can pull the starter cord but forget where the little knobs need to be turned to
I am not familiar with your model but general rules are as follows. 1 - make sure that the gas'oil mixture is the right ratio and that the fuel is not stale. 2 - Depress the little rubber primer bulb 4-6 times, or until yor see little bubbles through the bulb. 3 - Rotate the choke lever to Full and pull the starter cord until the engine tries to start. 4 - Rotate the chole lever to Half and pull the starter cord until the engine starts.5 - After the engine warms up, rotate the choke lever to Run or Open so that the engine runs smoothly.
Jul 01, 2011 | Garden
I have Honda self propel lawn mover and when I push the choke lever will go down from 1 and 2 setting and it gets stuck between 2 and choke.
Be careful here. New choke wires are expensive! spray white lithium grease into the choke assemply up at the handle, then follow the cable down to the engine, extend the choke cable inside the outer cable housing and try to get it lubricated white WD-40 or white lith gease. spary everything at the chole area with WD-40 OUTSIDE only - operate the choke manually and carefully a few times and git mowin!
May 13, 2011 | Garden
After starting it, It will run for a few seconds and then cut out.
are you running it with the choke on or off. this is the procedure i use for my chainsaw which can be a real pig to start if i don't follow this procedure.
1. Pump in the fuel 10 times.
2. Choke full on and pull 3 times.
3. Choke on half and pull three times.
4. Chole off and pull to start.
if this is the first time you have ran it for a lengthy period drain the fuel and replace and pump it through useingthe carburettor pump. It will be a pig to start but onse all the old fuel is gone it will eventually run fine. the reason for this is that the fuel these days can go off due to all the rubbish they put in it. it will form lumps etc that will block your jets etc in the carburretor. It would be really nice to know your model name and number etc and how you get on.....
kind regards
iain
May 04, 2011 | Garden
Qualcast petrol 35s mower will only operate with choke fully open, closing the choke causes the engine to cut out. Mower has been operating fine until now following a full service. What is the likely...
The chole is only ment to be used to prime the engine on cold start up, the engine is supposed to be run with the choke in the normally open position.
Aug 10, 2010 | Garden
I need computer help
Talk to *********** about this problem.
May 06, 2008 | Refrigerators
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
