Question about Refrigerators
Our frig. Is leaking water from bottom - Refrigerators
SOURCE: GE frig just starting leaking water at the bottom of the freezer side door
The water on the floor below the freezer door is due to an inadequate door seal. The door is not closing completely, either a foreign object at the bottom, or more likely, the freezer door gasket needs replacing.
Posted on Aug 25, 2008
bobicehouse
  • 1524 Answers
SOURCE: water leaking into the bottom of frig. going under veggy crispers
Look for the drain trough on the bottom of the freezer and pour a mixture of baking soda and warm water down.
Posted on May 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: water leaking onto floor from bottom of whirlpool
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
  • 30 Answers
SOURCE: Water is leaking from top part of freezer down to
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Posted on Oct 17, 2009
SOURCE: Water leaking. Mongram zic[s]360 (frig on top,
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Posted on Jan 24, 2010
Refrigerator leaking water
need info. disconnect from electricity supply look for a water collector in bottom rear of fridge if full of water drain out make sure drain hose into fridge is clear : if it continuies door sesl needs looked at as taking in to much warm air
Dec 19, 2012 | Refrigerators
The inside of freezer is leaking from back wall - there is no ice maker. water that leaks is freezing and taking up space. what can be causing this
the drain line is clogged causing the ice build up .the frig has to defrost every 6 to 8 hours so every time it defrosts is when it will leak ..you will have to defrost the frig manually ..turn it off. open the doors. let it defrost. remove the thick ice on the bottom ..after its defrosted take the bottom an back panel off.. un plug frig first !! drainline is in the back in the middle of the freezer. unclogg it hot water or shop vac be carefull good luck!! drain line should go to a pan under the frig, in the back make sure it drains before putting back together
Aug 21, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Water in the bottom of the frig, right side.
Find the condensate drain in the bottom of the frig and clear it
Jun 01, 2010 | Samsung RS2630SH Side by Side Refrigerator
Water running under frig.
have you tried turning the water off(if you have a tap/faucet behind unit).....
Feb 14, 2010 | Sub-Zero 650 / O Bottom Freezer...
Water always leaking out from bottom of fridge
If you have a ice maker check to see if the leak is coming from where the water connects into the back of the frig. If you dont have a ice maker. Look under the frig and be sure that you have a drain pan in place.
Aug 15, 2009 | Hotpoint Refrigerators
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
My frig is leaking water & bottom tray is full
you need to change the filter on the bottom of the refrigerator, take off the outside cover on bottom of fridge and on the left hand side right above the tray that keeps filling up there is a round filter that unscrews. unscrew it and replace the filter. You can get the filters at Lowes or Home Depot for about 20 bucks, hope this helps.
Jul 12, 2009 | Refrigerators
Water leaking into the bottom of frig. going under veggy crispers
May 07, 2009 | Refrigerators
Water leaking from bottom of unit
check to see if if drip pan leaking may be water line
Apr 07, 2009 | Magic Chef CTF1826AR Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
