Question about Toshiba TZ43V61 43" Rear Projection Television
Toshiab tz43v61 power light blinking
We are just watching the tv and it goes off and the power light just blinks. you have to unplug it and let it reset then it may work again and it may not. if it does work it may only work for a little while.
  • 1 more comment
  • Anonymous Mar 20, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to swndw's toshiab tz43v61 power light blinking problem, and notify you when a new solution is offered.
  • Anonymous Jun 10, 2008
    I WENT TO TURN TV ON LITE BLINK ONLY=REPLACED STK'S SET PLAYED OK FOR A COUPLE OF DAYS =NOW THE SAME THING
    CHECKED Q766 IS OK
    THANKS FOR ANY HELP THAT CAN BE PROVIDED
  • eazmik Aug 16, 2008
    tv on light clicks then light comes on and off somethime tv work after reset sometimes it doesnt
I had the same thing happen to me 3 times and the first time it was 2 months off of warranty. It is costing me $395.00 each time, the TV is only 7 years old. Lets see I paid $2400.00 for the TV and also have another $1185.00 into it for repairs, and it is doing the same thing again. My suggestion would be NEVER buy another Toshiba product. I find it interesting that their website says "As a proven technology leader, Toshiba is committed to the goal of ensuring that, to every customer, the Toshiba name remains synonymous with lasting quality, durability, and value." WHAT A LOAD OF ****!!!
Posted on May 17, 2008
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
Nov 02, 2012 | Mitsubishi Televison & Video
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
My power light is blinking,when i unplug it,then wait a few second,it stop,it comes on,then after 3mins,it gose out again,power light start blinking agin? why is this?
The TV is going into protective shutdown which can be many different items. But the most likliest by far would be the deflection board causing the issue. You can get replacement parts for that model from www.tvcircuitboards.com
Jul 24, 2011 | Toshiba TZ43V61 43" Rear Projection...
Tv switch on and off when press power button
IF power light comes on for a moment and then goes off:
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
Jun 21, 2011 | Mitsubishi WS-65511 65" Rear Projection...
When I turn the tv on the power light goes green for a couple of seconds then it shuts off and the picture never comes up.
Jun 03, 2011 | Mitsubishi WS-65315 65" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Redslight blinking have no picture
Have you replaced the lamp before? If not, I recommend you do it, since it may be what's causing this. There is power on the TV since you get the blinking light, so it's most probable the lamp.
Jul 31, 2009 | Toshiba TZ43V61 43" Rear Projection...
Power indicator blinks; but no picture.
Likely to be the STK convergence chips causing a protection circuit to cut in and switch the TV off when turned on. Do you hear clicking when you switch on?
Kelvin
May 28, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba TZ43V61 43" Rear Projection Television Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
