Question about Coffee Makers & Espresso Machines
Milk frother not heating
It froths but doesn't get hot help
  • 5 Answers
SOURCE: Aeroccino part for warming milk
you should contact nespresso to buy a new one.
www.nespresso.com
Posted on May 26, 2008
SOURCE: THE NESPRESSO MILK FROTHER HAS STOPPED FROTHING
I contacted Nespresso who may well replace the item
Posted on Nov 27, 2009
  • 21 Answers
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Posted on May 08, 2010
SOURCE: It just stopped making froth.
The milk frother must be extremely clean at it"s base. Hold frother up to the light and carefully examine the base for any type of filmy stuff.
Use a teatowel (dishcloth) or clean rag to polish the base and the problem will be fixed.
Posted on Dec 18, 2010
  • 8 Answers
SOURCE: the milk frother just boils the milk and does not
Hold the frother arm and pull the lower section off (It is in two pieces ) With the lower part off use a chopstick or something similar to push the small plastic nozzle out from the lower section,push from the narrow end .It will come out with a click,you will probably find it is blocked with dried ?congealed milk. Leave it to soak inhot water/wash up liquid and then use a nail brush to clean it also clean inside nozzle . Press nozzle back into sleeve untill it clicks into place and replace
Posted on Jan 30, 2011
My nespresso machine won't froth the milk
Brand of milk definitely matters... Here in Canada I used Sealtest 1% when I first used it and the froth was thick light and luxurious. Then one week picked up Neilsen 1% and found it produced absolutely ZERO froth. Back to Sealtest...back to froth. Milk brand matters....but don't know why.
Jan 14, 2012 | Nespresso Aeroccino Automatic Milk Frother
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Jun 07, 2011 | Gaggia Brera Coffee Maker
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
Feb 15, 2011 | Nespresso Aeroccino Automatic Milk Frother
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
The milk in the frother won't foam. I tried different kinds of milk but still doesn't work
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Sep 14, 2010 | Nespresso Citizmilk C120
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Coffee Makers & Espresso Machines Logo
63 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
