Need to know whis 2.0 model this unit is Serial # 501.3900.0599685
NEED TO KNOW THE TONNAGE ON THIS UNIT
2 1/2 ton. home is about 1200-1400 square feet ?
Apr 18, 2016 | Ruud Matching Split Air Conditioner
Which ipad has this serial #,Is this for ipad 1,2,or3? DN6FXJPYDKPH
Serial Number: DN6FXJPYDKPH
Model:- iPad 2 (WiFi)
Codename:- No codename assigned.
Build Country:- We don't know where this unit was built.
Build Year:- This unit was built in the first half of 2011.
Build Week- Week 26 (June)
Production Nr.:- This unit was number 2038 to be built that week.Serial Number: DN6FXJPYDKPH
http://www.appleserialnumberinfo.com/Desktop/index.php
Jun 16, 2015 | Apple iPad (16 GB) WiFi Tablet PC
What year is this model /
The serial number is needed to know the year of the unit. First 2 numbers are the month, second 2 numbers are the year.
Jul 26, 2014 | Goodman GPC1330H21A Air Conditioner
I'm trying to find out the age of my Beverage Air BM23 Kegerator. It's serial number is #823620I.
Scott,
Your Beverage Air Kegerator model BM23 / serial: 823620I - that serial didn't bring anything up when I called the manufacturer but based on the first 2 digits of the serial and the roman numeral 1 at the end of it - it would appear that your unit was manufactured in 1982 (If that number was on a metal tag then it defiantly was 1982).
We specialize in cooler gaskets and can help you locate the gasket part your unit needs. We also are able to get many other hardware and accessory parts for Beverage Air units and other manufacturers. Let us know if we can help.
Matt at coolergaskets.com
orders@coolergaskets.com
855-288-2259
Aug 25, 2013 | Beverage-Air BM23
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
I wanted to know how many Jennair downdraft electric ranges were out in 2000, with a sealed 2 unit burner and a grill and are there still replaceable plug in units for them?
Modules are still available for some models but you need the model and serial numbers of the range to find out what is available to fit it. The customer service number for Jenn-air is
800-536-6847. You might call a local appliance store if they carry Jenn-air products.
Jan 01, 2009 | Kitchen Ranges
Someone has an Intertherm outside 3.5 ton a/c unit for sale but doesn't know anything about it Model 5SQD-042KA Serial S5A070500546 Can you tell me how many SEER, heat pump or not,...
There should be a square sticker or metal plate that tells you the model # the #'s that comes close to the multiplecation of 12 =to tonnage,example ( asbv036g-1 the 36 = 3 tons 12x3=36 (gdhe420-1 = ==3-1/2 tons cooling 12x3 plus 6-1/2 ton = 3-1/2 tons the serial # tells the year it was made.....080808 , the first 4-#'s tells you the month--- for 4 #'s this is aug.- year 08 !
Sep 05, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
