Question about Car Audio & Video
Why does my car audio capacitor stop charging at 4.25v, thanks
?what is a capacitor?
A device used to store an electric charge, consisting of one or more pairs of conductors separated by an insulator.
Apr 17, 2016 | Power Acoustik Pcnc3.0f 5 Farad Digital...
How do I charge a nitro capacitor? I keep going out to my 280z and the dern battery is bled out due to capacitor not being charged and pulling directly from battery or when I stop for an errand and come...
hi,
just watch the following video . In the end of the video there is a method for how to charge the capacitor using a bulb. instead of fuse you can use a bulb to charge the capacitor. after charging completed insert the fuse.
ok
Mar 08, 2011 | Car Audio & Video
How do i charge it
To charge a capacitor:
connect it to a power source that has less voltage than the capacitor's tolerance.
Wait for it to be balanced with the power source's voltage.
The source must be DC.
Feb 20, 2011 | Rockford Fosgate 1 Farad Capacitor Cpc10...
How to install a zx-hypercap in to my car
Hello youngbossrio,
Like other car audio capacitors, the Volfenhag zx-hypercap has two terminals, a positive and a negative. The negative terminal is connected to the metallic frame of the vehicle (ground). The positive terminal is connected "in-line" with the amp 12V positive terminal.
The capacitor should be as close as possible to the amp. Within a couple of feet is acceptable.
The capacitor needs to be "charged" before connecting it directly to 12V positive. This is done with a 1000 ohm resistor and a voltmeter. The exact value of the resistor is not critical but it should be in the 500-1000 ohm range. Use at least a 1 watt resistor (your capacitor may have come with a resistor for charging).
Hope this helps.
Aug 26, 2009 | Volfenhag ZX-8300 Car Audio Amplifier
Boss 3.5s capacitor?
something in the order of 120 ohms. If you use a 1/4 watt size it will get extremely hot.
May 15, 2009 | Boss AUDIO CAP2C 2 FARAD CAPACITOR DIGITAL...
I enhance volume car light shimmer and amp off.
Need more info. Are you sying that your lights pulse to the bass? Capacitors help. I would recomend at LEAST a 2 farad. Make sure you are using GOOD QUALITY 4 gauge power wire. So many "kits" say 4 gauge, but strip it back and you have a glorified 8 guage wire. I've seenit. Also, MAKE SURE that it is ran to the bayttery and use the SAME gauge for the ground (no more that 4 feet if possible).
In case your next question is "how do I hook up a Cap?", here it goes:
Power AND ground to the cap, then power AND ground from cap to the amp input. So very easy!!
Take care,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Rockford capacitor question
I think the "chip" is actually a resistor for DISCHARGING the capacitor. If its hooked up right it should charge and the light should go out.
I dont think the "chip" is supposed to hooked to it when it is in use, but check the instructions..
Make sure the wires are right, and try it without the extra device attached to it.
wezmiester
May 25, 2008 | Rockford Fosgate CPCD05-03 Capacitor Car...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
