Question about LG Televison & Video
My LG tv model number 42LN5400-UA no picture
When i watched tv and video games my screen would go black so i took a flashlight and went across screen and could see picture. the tv has sounds but there is no led lights visible behind tv.
    Sergeant:
  • LG Expert
  • 330 Answers
It is a common problem for the LG 42/47 LN series LED TV, the problem is defective LED back lights strip (strips).
You have to open the display panel to find the bad one & replace it. The part number usually is printed on the strips, read 6916L-11XXA, you may purchase it from EBay.
Posted on Aug 11, 2017
Testimonial: "Thank You. This seems to be the right solution. I will look into this."
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Posted on Mar 15, 2009
  • 34 Answers
SOURCE: lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Posted on Apr 09, 2009
xptareq2000
  • 1447 Answers
SOURCE: lost picture on my LG 42" plasma model number 42PC1DV
it is problem high voltage unite problem (EHT) change it then solve your problem
Posted on Sep 03, 2009
  • 1039 Answers
SOURCE: Hitachi plasma screen black. blue light on... no picture though.
Replace digital board. Common for this set.
Posted on Nov 09, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a 1 year old sanyo 42" lcd tv, model
You need to find out if the power supply is putting out 24vdc for the backlight inverter board, it can be that the inverter board has short circuits which will cause the 24vdc to go into shutdown to protect itself, you can disconnect the power cables to the inverter board to see if you will get the 24vdc back.
Posted on Aug 17, 2010
We were watching and screen just went black model # LED55G55R120Q
Here's some troubleshooting steps to take: With the TV on and listening to a program, shine a flashlight on the screen. If you can see a faint picture the LED driver is bad. If you cannot see a picture the T-Con board is bad. You can get parts here and fix it yourself. It's easy. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 08, 2018 | Televison & Video
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Vizio VP50 has sound no picture
If this is an LCD TV, show a flashlight on the screen from a safe distance and check whether you can see the picture. If you can, the backlights or its circuits have gone bad. If you cannot, the TV needs attention of a qualified service technician.
Aug 12, 2012 | Televison & Video
Black screen no picture got sound
if its an LCD check by holding a flashlight to the screen looking for the pic. if u see the pic the backlight/inverter has failed.
Dec 06, 2008 | Televison & Video
Televison & Video Logo
282 people viewed this question
