Question about Garmin GPS
Hi. My garmin won't sync. It says the ant stick isn't in, but it is.
3 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: garmin forerunner 50 ant stick
Just open your watch and take out the battery and leave it for 15 minutes and put it back the battery.The purpose of taking out the battery is to reset to it's original setting.
Hope it may helps you;
Regards;
VOTIT
Posted on Nov 27, 2008
GPSCity Mike
  • 464 Answers
SOURCE: garmin 310xt software
Run the Garmin WebUpdater to load or reload the latest software to the device.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Posted on May 23, 2012
Vivofit adjust for daylight savings time. problem is with Garmin Express..can't get it to do anything. It says there is an update for this problem, but it says put vivo on sync to download.
I assume you mean you are trying to update via wireless. i think these will also update via cable. try that. Otherwise, you need to verify your wireless is working. sounds like the computer isn't seeing the unit.
Nov 13, 2017 | Garmin GPS
Garmin 310xt software
1-800-800-1020
May 15, 2012 | Garmin Forerunner 310 Xt Gps Sport Watch...
I have a new Garmin 410 and really struggle to get it do download via the ANT agent.
Once the USB ANT Stick is connected it should automatically start downloading.
Make sure the Garmin Communicator Plugin is up to date for Mac OS.
http://www8.garmin.com/support/download_details.jsp?id=3739
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Nov 11, 2011 | Garmin Forerunner 410 with Heart Rate...
Garmin Forerunner 405 always shows wrong time/date
Turn on the GPS. The forerunner will automatically sync time and date. Make sure the DST is switched to auto. I had the same problem and researched for the answer....which led me here. Turning on my GPS sync'd time and date for me. I hope this helps
Jan 02, 2009 | Garmin nuvi 200W GPS
Cant install Garmin Connect software
reboot the computer in safe mode. (HIT F8 during the startup) then after the computer loads put the ANT stick in the USB slot and it will then be recognized.
remove it and then reboot normally. Now simply reinsert the ANT stick after starting the ANT agent.
worked like a charm
enjoy
Dec 03, 2008 | Garmin Forerunner 405 Handheld GPS...
Garmin forerunner 50 ant stick not uploading to my computer. data history on watch.
Regards;
VOTIT
Nov 26, 2008 | Garmin Watches
MY Garmin 405 wont download data. It make the connection and gets to the tarnsfer point then "transfer failed. I've one route downloaded last week but none since. I tried: resetting both...
I got the same issue and it was because of a software update to ANT+ agent being not compatible with the 405.
here is what I got from Garmin Support.
This solved my problem:
There is currently an issue that has been identified with the latest
version of the ANT agent where it will not transfer data to the computer
from a 405cx. To resolve this please follow these steps
1. If the device has paired it will need to be removed. Right Click on
the ANT agent, select Device Settings then click Remove Device.
2. Right Click the ANT agent and select Exit to close the ANT agent
3. Go to the Control Panel, select Add / Remove Programs and uninstall
the ANT agent.
4. Reboot the computer
5. Download the previous version of the ANT agent from http://www8.garmin.com/software/GarminANTAgent_221.exe
Run this file once it has downloaded
7. Turn on the pairing on the watch ? to do this go to Menu > Settings
> ANT+ > Computer > Pairing (on).
8. Enable pairing on the computer - right click on the ANT agent icon
and select Pair With New Devices > Enabled (this may already be enabled)
The Forerunner and computer should now pair, please be aware that it can
take several minutes for the computer to find the watch.
May 14, 2008 | GPS
Sync problems with windows vista
I got a Vista computer in April and have problems also. You need a special program to install the maps. email Garmin and they will send you the link. An SD card reader/writer is MUCH faster than the sync.
I didn't have syncing problems until after I tried to install Documents to Go. I had to remove Doc to Go v6 because it was making my computer unstable. Doc to GO V10 works with Vista but requires Palm OS6. Garmin says that Palm OS6 can't be installed on the Garmin iQue because they added proprietary software to OS4. I believe my sync problems will disappear after I reload the Palm Software.
Feb 18, 2008 | Garmin iQue 3600 GPS Receiver
GPS Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
