Cant sync. It says the ant is not connected but it is
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
How to reformat nokia 5130 c-2 with the security keyguard forgotten
Follow this procedure to generate your security code.This trick will work only when after your phone connect your PC via Usb cable. 1.Downoad [ANT] Simple Ant Simple.zip Ant Simple.zip2. If you have Nokia PC Suite running, be sure to close it by exiting from the task-bar icon.3.Extract [ANT] Simple ] and run Simple.exe located in the folder4.Connect the phone via USB(should be original Nokia Data cable) to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.5.After you've connected your phone, Click "Read Info"6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed onthe bottom panel as shown below7. Nowclick on the SERVICE tab and click on GET button under USER CODE8. Your security code should now be displayed on the right side of the application window. After all format it by selecting "Restore All" from your phone setting.Thanks For visiting Fixya
Feb 27, 2012 | Nokia 5130 Cellular Phone
I have recently got a Samsung Galaxy S I9000 and when I try to connect to my blueant st3 a message comes back that the blusant rejects the pairing with the phone. I used to use the bluseant with a nokia...
Darrell 12/11/2010. make sure you have the phone set to sync then press green button on ST3 until it ask what language you require keep it pressed until it states on the screen that you want to sync press ok and you will find that it has connected. You can use the same system to sync it to an I Phone as well
Nov 06, 2010 | Blueant Blue Ant 091193 Supertooth II...
I cant get my farmville farm to load fully, it only get 95%. Ant suggestions?
connection problem or the system. but usually connection problem in your area slow connection
Jun 12, 2010 | HP Pavilion dv6000z Notebook
Ipod touch wound sync to my computer. i had a nano first. when i tryed to sync my ipod touch i did not reg. to my computer, i just tryed to copy my music to the new ipod. my daughter shares our music from...
Open iTunes (without iPod connected). Create a new playlist and copy songs you want on your iPod into that list. Next connect your iPod. Once iTunes recognizes your iPod then go to the music tab and click on 'sync playlist only' and chose the new playlist that you created. Click sync. Only the songs in your new playlist should be copied to your iPod.
Dec 30, 2009 | Apple iPod touch
I cant sync my iphone to my blueant. I was able to but i got a new phone and lost the instruction book and cant remember how to do it
On your phone, try Settings > Connectivity > Bluetooth > (turn on) > Phone visibility (shown to all / on) > Search for devices >Choose headset (when located)
The password is 0000 (four zeros)
I don't have the link for the Super tooth II manual. but here's the link for the Supertooth One manual: (it may help)
http://www.supertooth.net/img/one/mdp_EN.pdf
You'll need Adobe reader to view it. It's free. Download here if you need it:
http://get.adobe.com/reader/
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Nov 10, 2009 | Blueant Blue Ant 091193 Supertooth II...
Won't sync music to player using windows vista
sir there may be a problem with your pc's i/o devices.virus present in the pc may also lead to this problem.use an apt anti irus to your system ant the prolem will be solved.
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
How can i transfer my contacts from nokia phone to my HTC Touch
There are few tools to have. A usb cord, your PC has Bluetooth and pair with you N51 via bluetooth. Have the free software, "Nokia PC Suite". Download it from www.nokiausa.com/PCsuite. It's a free download. Once downloaded, restart your computer. (without the phone connected) Connect. It'll give you easy step by step instructions to transfer contacts to the computer. Plus, other multimedia you may have on your device. Very handy!! Then, just use Active Sync or any software you got with your HTC Touch HD. It can sync you contacts from Outlook onto the new phone. This is nice, in case your phone would crash, break, or the worse stolen. Your contacts are all backed up on the PC.
Always take a look at www.htcwiki.com for the best tips & tricks for your HTC device and software updates. A lot of times they will even post known issues and work arounds.
Feb 10, 2009 | HTC Touch HD Smartphone
Cant install Garmin Connect software
reboot the computer in safe mode. (HIT F8 during the startup) then after the computer loads put the ANT stick in the USB slot and it will then be recognized.
remove it and then reboot normally. Now simply reinsert the ANT stick after starting the ANT agent.
worked like a charm
enjoy
Dec 03, 2008 | Garmin Forerunner 405 Handheld GPS...
No Signal
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Sep 05, 2008 | Mitsubishi WS-55807 TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
