Question about Sony Televison & Video
How do I connect wireless headphones to Sony bravia TV
joboo1
  • 257 Answers
SOURCE: can't connect wireless stereo to sylvania 6620LF4
Hi, Ok, I now understand what the problem is. Sorry I missed the fact that it is due to no audio outputs on the TV. The audio board is designed to power low impedance speakers and doesn't have a big power amp to drive them. I do not have a schematic of that particular TV so I do not know how the headphone jack is wired. The way it basically works is, when you insert the plug, the tip pushes a contact away from another contact thus making one circuit and breaking another. You can test this externally by inserting an unwired plug or look at it from the inside and bridge the tip connection. I would only advise this if you have some technical skills. Other than that the thing is working like it was designed, they don't want you to use both. Sorry, I hate to give this type of news, but I am one of the only ones who will. Good Luck to you!
Posted on Feb 20, 2009
farr64
  • 121 Answers
SOURCE: connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Posted on May 01, 2009
PCTechOnline
  • 532 Answers
SOURCE: how do I connect Acer Aspire One to sony bravia tv?
Then use a VGA cable to connect to the PC IN on the TV.
Posted on May 01, 2010
  • 5 Answers
SOURCE: Sony Bravia 40
go to your remote contol ( menu )
then you go to the option set up.
then you go to headphones and you can set the volume louder.
You will see that it works fine.
Greetings from Holland Gesinus
Posted on Aug 15, 2010
Geekman
  • 32281 Answers
SOURCE: i bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Posted on Sep 23, 2012
Can I use a harman kardon hk3370 with a sony bravia tv for surround sound?
Yes you can only if you know how to connect.you can use headphone port on bravia as audio in from hk3370
May 15, 2016 | Sony Audio Players & Recorders
Sony Bravia tv, can't get sound out of wireless headphones with base station plugged in
Check the Volume on the TV, the audio jack is tied to the TV volume control.
Jan 09, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Bravia hdmi hdtv lcd
It will be so. When you insert the headphone pin into its socket, the internal speaker connection will be automatically cut off, and you can listen the sound via the headphone only.
Sep 28, 2013 | Sony KDL40EX600 TV
We have KDL-55EX711 Bravia and want to connect to the Internet. Shaw has given us a wireless modem but we can't connect. Help please!
I too just bought the KDL-55EX711 Sony Bravia and have connected it to the internet. This TV is awesome! To connect to the internet, however, you still need a wireless access point or wireless router to have that the TV can communicate with.
The TV comes with a wireless USB ethernet card "dongle" that you must plug into the USB slot on the side. After connecting the USB wireless card to the TV, connecting to the internet is just like connecting a laptop to a wireless network. You must go to the network settings menu on the TV follow the instructions there to get connected. In a nutshell, the TV will list the available networks to connect to. Find yours and try to connect to it. If your network is secured, you might need to enter a password that you have already set up for your wireless network. Finally you can either enter have the TV ask for an IP address and other settings or enter them yourself. You should not try to enter the IP address and other values yourself unless you know what you are doing.
Feb 19, 2011 | Sony Televison & Video
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Where do I find the place to connect headphones on the bravia xbr
Try this: face the television; Left hand side on the edge; Look for the green input port (top hole); plug in headphone jack; should work
Dec 22, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
