Question about Sony Televison & Video
Where do I find the audio output on a Sony bravia tv
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Hi John,
if you're using the HDMI cable then the sound will be carried via that cable along with the Video signal. If you're connected via RCA's the Stereo output will be the Mini-HIFI jack that looks like the earphone jack on most cell phones. The Bravia also has the option for Optical output.
Where do I find the audio output on a Sony bravia  - screen shot 2017-08-11 at 7.02.44 pm-5e1rsgzfmkhy3a0azavq0fmu-3-0.png
Posted on Aug 11, 2017
  • 56 Answers
SOURCE: convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Posted on Jun 12, 2009
  • 541 Answers
SOURCE: connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Posted on Oct 24, 2009
Testimonial: "Thanks for your help. George"
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
falter
  • 245 Answers
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Posted on Nov 20, 2009
  • 50 Answers
SOURCE: How to connect my audio system directly to sony bravia
There is usually three ways to connect a TV to a Surround Sound system:
1. Optical Audio Cable (Fiber Optic)
2. Coaxial Audio Cable (Orange)
3. Composite Audio Cables (Left - White, Right - Red)
Once you select a cable to use that is compatible with both devices, you must then connect it to the output on the TV set, and one of the inputs on the Surround Sound Receiver (preferably the Video Input or whatever type you selected to use). Then you must change the input on the Receiver to the proper input that you connected the cable to (most Receivers will have a Source Button if not individual source buttons i.e. Tuner, Tape, CD, Video, Aux, etc.).
Note: Some Receivers if using a certain type of input will not have sound out of all 5 speakers unless the input is 5.1 compatible.
Posted on Jul 02, 2010
How to connect sony bravia tv to amp
If set has RCA audio outputs, connect the outputs to an input on your amp, say aux, etc. Then set your function control to "AUX" and the audio from your set will be amplified.
Apr 11, 2015 | Sony Audio Players & Recorders
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
How can i connect my 32" sony bravia?because the
Route the television audio directly through a stereo receiver. Connect the audio outputs of the television to the audio inputs of the receiver, using digital (coaxial or optical) or RCA (left and right audio) cables. Connect the left and right stereo speaker to the corresponding terminals on the receiver. Be sure that the positive and negative terminals of each speaker and the receiver are correctly lined up
Use a cable box. If your television doesn't have audio outputs, as many older TVs don't, use the outputs from a cable box to route your sound to the receiver. Proceed with a digital or RCA connection as described for the TV
Use a VCR. If you don't have a cable box, run the cable from the wall outlet into your VCR and then instead of outputting the audio to the TV, output it to the receiver so that you'll get sound from cable programming through the receiver and to the speakers, rather than to the TV. Connect the video output from the VCR directly to the TV for the easiest setup. You will then need to control your television programming with the VCR.
Change the program mode on the receiver to the input category you used to input the audio; for example, "TV," "Cable" or "Aux" are common options. You should now be able to hear audio from television programs on your speakers.
Mar 01, 2011 | Durabrand 5.1 Surround Sound Computer...
I just connected my brand new sony bravia tv and have no audio with my satelite
You may have the audio jacks on the wrong input,output. Try pressing the remote for another video option. You may find you have audio and no picture. If this is so, relocate you rca jacks once more. Good Luck and thanks for asking!
Jun 20, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Connecting speakers.
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Can't play audio CDs without having the TV on
Your description is not entirely clear, so I have to guess a little here, but I think what is happening is as follows:
1) You are using your DVD player as the source for the CD.
2) Your DVD is connected directly to the TV and the TV then connected to your receiver.
If the above are correct, then the problem is that the TV only has what is called an ACTIVE passthru for Audio signals. This means that the signal is process by the TV and tehn sent to the audio output jacks. With the TV off, the buffer ICs are not functioning, thus no output. Some older sets have what is called PASSIVE passthru.
I don't know your specific DVD model specs, so check to see if you have 2 audio outputs from the DVD (many do) and connect the other audio out directly to the receiver. That will resolve your problem.
Dan
Mar 20, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
Televison & Video Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
