Question about The Audio Players & Recorders
I am looking to use BT yourview box on my Techwood 40A012B model but cannot get the TV to " receive" via the HDMI slot
SOURCE: receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Posted on Dec 13, 2007
SOURCE: Screen flickers on / off when run through receiver
just restart the cable box this will fix the problem. My problem started after a power outage and it was fixed by rebooting the cablebox
Posted on Feb 09, 2008
  • 151 Answers
SOURCE: Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
Posted on Jun 29, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
Number please for bush tv to bt yourview
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 12, 2014 | Bush 2871NTX 28" TV
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
Mar 21, 2010 | Sony STR-DG1000 7.1 Channels Receiver
How do I convert from HDMI-in to Component-Out? Basically, I'd like to have my cable box (Comcast DVR) coming into the receiver using HDMI but would like to output to my TV using Component instead of HDMI....
looking at the manual here that should work for Video
it looks like on the receiver you would have the DVR connected via HDMI cable to the receiver On the receiver you would select this HDMI as the input. That should automatically allow that signal to be presented to the component out on the receiver you connect the cables from component out to the TV and switch the TV to select the component input -depending on the TV model this may be labeled AV1,2,3,4, etc No sound will be transferred to the TV as component is Image ONLY whats the make and model of the TV
Mar 20, 2010 | Onkyo TX-SR606 Receiver
Hi ive been offered a techwood twp4210 plasma tv and i have a couple of questions can you advise if this is hd ready also how old are they, have also been advised that on start up it shows green sparkles...
The unit was being manufactured in the early to mid 2000's but I believe is not out of production. It is NOT an HDV. Here are the specs for the TV.
Product details Manufacturer Techwood Built-in Sat-Tuner No Compact Flash Card No Digital Tuner without Digital Tuner DVD Player / Recorder No HDTV Norm No Loudspeakers without Loudspeakers Memory Stick No Multi Channel Receiver without Multi Channel Receiver Type No Multimedia Card No PCMCIA Interface No Common Interface Slot No DVB-C No DVB-S No Screen Format 16:9 Screen Size in cm 106 cm DVI Interface No Electronic Program Guide (EPG) No Screen Size in Inches 42 in Secure Digital Card No Energy Savings Trust Feature No HD Tuner No Smart Media Card No Type of Monitor Plasma Display, Plasma Horizontal Resolution in Pixel 852 PC Interface No Vertical Resolution in Pixel 480 Brightness in Candela/m² 650 HDMI Interface without HDMI Full HD without Full HD (1080p) DVB-T without Digital Tuner HD ready Not HD Ready LED Backlight without LED Backlight DLNA certified No Energy Saving Trust Feature No HDMI No HDTV No Internet Access NO WEB CONTENT ACCESS EAN 5017416142205, 5017416183666
Nov 19, 2009 | Televison & Video
I am trying to connect my ps3 via hdmi, digital cable box via fiber and my tv via hdmi. I cannot get the picture to display on the tv. Any suggestions?
I connected a fiber optic cable from the cable box to the receiver and connected an hdmi cable from the cable box to the tv.
Sep 30, 2009 | Samsung HT-TZ512T Theater System with...
Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Jun 05, 2009 | Yamaha RX-V463 Receiver
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
No solution, but I have the same problem with my Panasonic plamsa TH-50PE700U with a Yamaha RX-V2700 receiver. I don't think the cables are a problem. If I turn the TV on and off about 20 times the system stabilizes until I turn it off.
Sep 03, 2007 | Audio Players & Recorders
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
