Question about Pantech Matrix Cell Phone
It goes in and out of service constantly. Sometimes it says no service and shows no bars. then other times it shows bars but says emergency calls only. whats wrong?
My TRACFONE Lg 800G keeps saying emergency call only when I have full service
This problem shouldn't really have anything to do with the signal your getting. the emergency calls only mode is intended for prepaid phones without minutes or contract phones that are deactivated.
That being said, there have been a lot of problems with the 800g sending certain types of data over networks, since your prepaid phone is constantly sending data regaurding your prepaid time, it may just be that the data isn't being sent or recieved properly thus either your phone or the network thinks you are out of time. try taking out your sim card see if you can tell if it is an ATT sim or a T mobile sim, if it's ATT its a pretty good possibility that that is your problem. Either way if your getting the emergency calls only screen and you've got plenty of minuts on your phone I would contact tracfone and tell them what's going on.
and a little FYI: they may try blaming it on your cell number, if you've had the same number for a long time and havent had any problems, dont let them bully you into getting a new number, chances are it wouldn't help anyway
Sep 01, 2012 | LG800G
I bought a sharp 903sh online through YesAsia. On my pc it shows up a sx833. I can't make or receive calls but it will send and receive texts. System sounds eg text arriving,are fine but the voice...
Dear Amaxeen ,
Well It Seems the configuration problem ,you should have to configure your phone properly for that ,if you wanna to use its aal features you need to download proper drivers and manual ,so that you can use it smoothly.
You can download all stuff for your Sharp 903 , from this link:
http://www.sharp-phone.com/country/downloads/downloads.php?country=GB&lang=en&product=903
Cheerup and Be Happy Always
Mar 07, 2008 | Cell Phones
"emergency calls only"
Try resetting the phone. If that doesn't work, show it to a cell phone repair store. It maybe an issue with the IC that regulate the Cell phone signal.
Sep 21, 2017 | Samsung Focus i917 (8 GB) Smartphone
SIGNAL STRENGTH IS EXTREMELY POOR COMPARED TO OTHER PHONES ON SAME NETWORK
your phone antenna have some problem just open your phone if your phone out of warranty and make sure your antenna contact point is clean
May 21, 2012 | Motorola Mobility W173 Cell Phone
When i call or text is says service unavailable or sometimes it says emergency calls only!
the problem with ur phone is if it is in a no call zone or if the bars on ur phone are a dark blue then u cant call or text and sometimes it will show a phone with a red line through it sometimes it is just where u r standing hope this helps and if worst comes to worst then you will have to take it in and get it replaced by ur insurance.
Aug 10, 2009 | Samsung Propel A767 Cell Phone
Samsung u900 only allowing emergency calls
You phone service is turned off call your cellphone provider
Aug 09, 2017 | Samsung SGH-U600
My motorola is showing `` no service and emergency calls only ``
it has to be bad reception....have u tried contacting ur netwrk service provider...plz do check with them and update me...
Thanks for using Fixya!
tc
Sep 03, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Emergency calls only
um i really don't have a solution but when i turn on my phone it says emergancy calls only and shows a phone x out in the left top corner even though i have all bars and i try taking out the battery and stuff but it doesnt work. at the bottom of the screen it says Smartchip not provisioned MM #2. Can someone help?!?!?!?
Jun 27, 2008 | LG KG800 Cellular Phone
How di remove call barring from nokia 5500d
Call barring
Call barring (network service) allows you to restrict the
calls that you make and receive with your phone. To
change the settings, you need the barring password from
your service provider.
1 Select Menu > Tools > Settings > Call barring.
2 Scroll to the desired barring option, and to request the
network to set call restriction on, select Options >
Activate. To set the selected call restriction off, select
Cancel. To check whether the calls are barred, select
Check status. To change the barring password, select
Edit barrings passw.. To cancel all active call barrings,
select Cancel all barrings.
Call barring and call diverting cannot be active at the same
time.
When calls are barred, calls still may be possible to certain
official emergency numbers.
Apr 09, 2008 | Nokia 6288 Cellular Phone
Pantech Matrix  Cell Phone Logo
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
