Question about Sewing Machines
I have been using my designer 1 for embroidery only for some time. I just went to use it for regular sewing and feed dogs won't come up. I have checked settings and all are correct.
  • Sewing Machines Master
  • 11,444 Answers
Just a reminder. Feed dogs do not raise until the handwheel is activated.
Posted on Aug 11, 2017
Testimonial: "I have turned my handwheel, tried sewing etc. I haven't used my machine for regular sewing for some time, but last time I did, I had no issues."
  • 482 Answers
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Posted on Dec 16, 2007
SOURCE: Feed Dogs Kenmore 158.19802
I think the feed dog lever needs to be positioned on the right.
Posted on Jan 15, 2009
SOURCE: Feed dog won't come back up after embroidery is
I didn't "get" the "full rotation" and fought with my new-to-me Viking Rose 605 for an hour to no avail, eventually installing and uninstalling the embroidery hoop. Then, I slid off the bobbin cover AND the feed dog cover, poked the feed dogs with my tweezer, and they released.
Posted on Sep 07, 2009
SOURCE: Babylock Ellageo will not feed after using
I have an ellageo EGS the thread from the bobbin comes up to the top and sometimes the spool thread winds into the boobin
Posted on May 26, 2010
  • 4 Answers
SOURCE: USB drive does not regularly read the USB flash
I have a Designer I USB that suddenly started not reading the usb stick that came with the machine. I was terrified that my machine was going bad, but I always start with the cheapest solution first. I bought a new usb stick, loaded the designs from the old one into my software then loaded everything on the new usb stick. My machine reads it every time so far. I replaced the usb stick about 3 months ago and have not had another problem since. I don't know if this is your problem, but usb sticks can go bad and since they are so cheap, I would try this first.
Posted on Jul 13, 2010
How do I Lower the pressure foot for sewing after changing from embroidery on my brother pc- 8500?
Would a manual help?
Brother PC 8500 User Manual
Are the feed dogs in the raised position? Is it a regular stitch presser foot or a darning foot? A darning foot is shorter in height so the fabric can be maneuvered without use of the feed dogs. Just some ideas. Could also be an embroidery setting that has not been deactivated.
Oct 03, 2016 | Brother PC-8500 Pacesetter Embroidery &...
How to bring sewing foot holder to embroidery position
Hi, I hope this helps. If it doesn't post again.
Place the sewing foot under the sewing foot
holder so that the pins of the foot snap into
the sewing foot holder when the presser foot
lifter is lowered.
Please check that the sewing foot is properly
engaged by raising the presser foot lifter
Question: Are you using top feed? If so:
"For all sewing jobs with the top feed, only use sewing feet with Cutout at the back (OA, 1A, 3, 4)."
Embroidery foot Part No.: 98-694-840-00 will not work with top feed.
Also, except for eyelets, the darning foot can be used for embroidery.
I'm not sure what you're trying to do :) darn or embroider :); I'm not sure what mode you're working in either; embroidery mode?
Darning with straight stitch
Program 00
Fit darning foot No. 6.
Set the needle at its highest position by turning
the handwheel, and push the pin of the darning
foot fully into the hole of the sewing foot holder
slightly pressing the darning foot between thumb
and forefinger. When doing this, the guide fork
should place itself around the presser bar and the
wire must be behind the fixing screw.
Darning position:
Lower the presser foot lifter pressing it lightly to
the rear until it snaps into the darning position.
Important Only in this position you have the
optimum thread tension for darning.
• Place the darning work in the darning hoop.
• Lower the feed dog.
• Pull up the bobbin thread and hold the threads
when you start sewing.
• Now guide the fabric back and forth evenly;
the length of the darn will be set by the size of
the hole. As you are determining the stitch
length yourself while sewing with the feed dog
lowered, you should sew at an even speed.
When you have reached the width of the dam
aged area, darn over the damaged area again
from right to left.
This guarantees a durable darn.
TIP: The faster you sew, the easier and more even
the darning will be. It you are moving the workpiece
too slowly, small knots will appear on the
wrong side of the fabric."
Whether working with terry-cloth or woven fabric,
with the help of the darning foot and the pro
gram 02 you can embroider initials of your own
Drop the feed dog and insert the darning foot.
Put the machine into the darning position.
Spread the fabric in an embroidery hoop and
embroider in accordance with program 02.
Lower feed dog
If the feed dog is not lowered for embroidering, the
machine does not embroider when the foot pedal
is pressed and the message appea rs:
Lower feed dog
The feed dog must be lowered in embroidery
Jun 20, 2015 | PfaFF Creative 7570
Can't get the feed dogs to come up on my Singer Futura XL 400 sewing machine
Hi Susan,
Happy New Year!
try engaging the "Feed Dog Switch" and turn the flywheel on the side with a gentle back n fourth motion. Sometimes they get stuck with all the fuzz and buildup in the switch mechanisms from use. If that doesn't get you going, a visit to the authorized repair shop might be needed.
Embroidery Services
San Diego, CA
Jan 01, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
How to stich embroidery
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
Nov 03, 2012 | Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
After using the embroidery hoop you can not sew in regular mode, feed dogs does not come up and moved the cloth.
My Janome has a metal slide switch for lowering the feed dogs on the base of the machine in front.
Have you raised the feed downs again? Otherwise, turn off so that the current stich selected resets, and then turn on and select straight stich. Try again.
Feb 27, 2011 | Janome Sewing Machines
The dog feed stuck in the downward position.
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Feb 19, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Sewing from m-memory
Hi Ann,
m-memories are not stitched with the hoop or embroidery unit. They are stitched with the #2 sewing foot and with the feed dogs up just like any of the 9mm decorative stitches on the machine.
Nov 07, 2007 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
