Question about Refrigerators
Only 30 mins on its side - Refrigerators
MY FORD FIGO MUSIC SYSTEM ASKING WAIT 30 MIN WHO TO REMOVE IT ?
Call the dealer service dept and explain the issue.
May 12, 2016 | Ford Cars & Trucks
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
Mircoway stops after 5 mins of cooking
there wiil be some paint of the in side
Apr 29, 2010 | Maytag Over-the-Range Microwave
Is it Ok to lay a refrigerator on it's side for a short time (less than 30 min.) while moving.
Yes, you can, but allow a couple hours in the upright position before turning it back on.
Aug 15, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
Kitchenaid Model KGST307HBS5 intermittent will not heat up
the gas leak can be the safety valve. in side the oven where the burner sits on you have to remove the burner to get to it.
Dec 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
