Used channel scan lost 4 channels is there a way to add channels
bkvinr
  • 76 Answers
SOURCE: can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Posted on Sep 09, 2007
sir fixalot
  • 146 Answers
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Posted on Jan 04, 2008
SOURCE: scanning channels stops at 20%
the exact same thing happened to my dta800. i unplugged the ant. input at 20 percent and then plugged it back in when it resumed. i dont know why this worked, but i now get my 25 channels instead of the 4. this digital garbage is annoying all around. hope this helps. senor punko
Posted on Jun 22, 2009
  • 508 Answers
SOURCE: l channels deleted fro memory how can i add all the channels back
push channel button then add!!!!
Posted on Jun 28, 2009
emissionwiz
  • 80407 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Nov 03, 2017 | Televison & Video
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
How do I reset my kenwood TK-3212L
ADD TO SCAN/ DELETE FROM SCAN
Press the key programmed as Scan Delete/Add to add or
remove each channel to or from the scan sequence.
• The channel add indicator ( ) will appear on the
display when the selected channel is added to the scan
sequence.
Press and hold the key programmed as Scan Delete/Add to
add or remove each zone to or from the scan sequence.
• The zone add indicator ( ) will appear on the display
Oct 14, 2014 | Radio Communications
Can I manually choose what Air channel I want to be using?
It doesn't matter what channel number it ends up on after a scan, as long as you do the scan with it fired up it should detect it. You should then be able to edit but why bother?
I don't understand how a channel number can be described as dumber than dirt, if it does not detect it on an autoscan through ALL channels it won't work manually.
All that said you will get much better results using the video and audio outputs rather than the modulated rf feed. Look here for how to get to those outputs, your TV will need a composite and audio input for that to work.
SEGA Mega Drive Genesis RCA Mod Tutorial Add Video And Audio Outputs To...
Jun 16, 2014 | Sceptre E465BV-FHDD 46" 3D LED TV...
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Lost channels on a Sony KV-1972R
Go to menu and select add/delete channels. Then select 02, or 03. Some channels that are selected the numbers will show green, channels not locked in will be red.
Jan 18, 2009 | Televison & Video
I have lost my tv channels!
I have a philips freeview box (although it is not built in). I recently lost all my channels also. It took me back to the installation screen and started to look for channels, furthermore if it couldn't find any it 'bugged out' on me. The only way I got around this was by unplugging the aerial, watching the screen trying to scan the channels and when the progress bar / channel # was near the end plugging the aerial back in. For some reason this started the scanning over again but this time it found channels! Strange I know, but maybe its different for me and one of those conspiracies that they program products to fail after a few years to make you buy more. Try this and let me know if it works Thanks Matthew
Jun 18, 2006 | Philips 26PF5320 26 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
