Question about Vizio Televison & Video
Vizio m55-c2 tv with a double image or shadow like image on the entire screen. Ive replaced the tcon board and checked all connections with no luck in fixing the problem. Where should I go from there?
  • Vizio Expert
  • 296 Answers
The problem mostly is a defective LED panel, we see a lot of them.
Posted on Aug 11, 2017
  • 1 more comment
  • Nicholas Thrash
    Nicholas Thrash Aug 11, 2017
    Thank you. Is there any way to test that it is the led panel that's faulty?
  • City View TV & Computer, Inc.
    The only way to test it is to move all of your boards to a same working TV to verify that all of your board are OK, also please contact Vizio customer support, some of the Vizio models are under extended warranty on defective LED panels.
  • Nicholas Thrash
    Thank you for the excellent advice. I will be sure to contact Vizio.
  • 5568 Answers
SOURCE: TV has shadowing double images/colors are uneven
It sounds like the problem one can have from a weak signal. This kind of problem is normally associated with the use of an antenna which is receiving the primary signal, then a secondary one that is being reflected to you from a distance; an echo. The first signal is the one you are seeing best, then from some distance, the same signal is being sent back to you with a time delay of a few microseconds causing a shift in the images. A repositioning of the antenna orientation is the only solution.
If you are on cable, you will need to call them and holler about the signal quality. Thinking this through, I don't think this can happen when receiving satellite signals since the antenna is pointed toward the sky and the chances of any noticeable reflection are close to nil.
Posted on Nov 26, 2008
  • 42 Answers
SOURCE: 53 Hitachi Rear Projection TV with shadows and double images
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Posted on Feb 08, 2009
SOURCE: verical lines on half of the screen
I have the same prob. Please help my *** out here!
Posted on Jun 15, 2010
  • 12 Answers
SOURCE: I have a vizio vz37l tv. When i turn it on the
its the main board...
Posted on Mar 07, 2011
  • 517 Answers
SOURCE: I have a olevia model 232-s12 tv has sound but no
Good day.
If you already replaced a new inverter board and T-con board and the problem is still there.Try to play the video on the DVD,if the video is OK check the cable connection and try to run auto scan.
If the problem is still there check the input supply of the system board or main board it should have 5vdc and 12vdc,if it is OK replace the system board.
Review this manual page 4-1 abnormal display
I hope this solution will be helpful.Thank you for using FixYa.
Posted on Apr 17, 2011
How do I repair horizontal lines on my Vizio flat screen tv?
The TCON board or the LCD Panel is faulty. Can confirm by replacing the tcon board,
If you wish to get some details about TCON board problems ; check the site linked here. Pull up older posts.
Nov 23, 2016 | Vizio Televison & Video
My vizio smart tv model e550i-a0 has black screen and audio ,the back lights are on and the power light at the bottom comes on and is white
The TCON Board or the lcd panel is faulty. Can confirm by replacing the TCON Board. To know more about TCON board fault and troubleshooting check the below added link .
Nov 02, 2016 | Vizio Televison & Video
Vizio 37 inch TV has blue line across top of screen when I turn on after a half hour it grows and TV works good till I turn it off for more then a hour any suggestions
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board .
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 09, 2016 | Vizio Televison & Video
Vizio 55" E55-C2 LED backlight issues. Was working fine until one day half of the screen's backlight stopped working and so half of the TV shows good and the other half is darker. Tcon or LED driver?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 13, 2016 | Vizio Televison & Video
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem.
Apr 08, 2014 | Vizio Televison & Video
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
