Question about Sewing Machines
What size needle 7422 - Sewing Machines
  • Sewing Machines Master
  • 12,009 Answers
What's the make of the machine?
Search for:
Make Model needle
Posted on Aug 11, 2017
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Singer 7462 will not pick up bobbin thread
You need to adjust the needle timing - called "timing the needle".
How do to that is usually included in the service or repair manual for your model of machine. There are various online shops where you can order this.
Also, the machine is pretty similar to the Single 7422, and there's an ehow article on how to adjust the timing on that model that you might find useful.
http://www.ehow.com/how_7799647_adjust-singer-7422-sewing-machine.html
Dec 01, 2013 | Singer 7462 Mechanical Sewing Machine
The top thread is not picking up the bobbin thread. Singer Model 7422
Check your needle and make sure it is not bent, needles should be replaced after about 8 hours of sewing and that they are the right size for your project. Also use the same weight of thread, do not mix ie. cotton or polyester. Then check your threading, did some thread get tangled? Or sneak out of a guide? Hope this helps.
Oct 03, 2010 | Singer 7422
Needle is hitting plate under the bobbin
ure needle is too long. They sell differant size needles
Nov 18, 2008 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Bobbin case turns in its place
You need to remove the needle plate and take out the bobbin case. Examine it for any rough spots, scratches or burrs. When you find them, you will need to remove them with an emery stick and then buff it with very fine steel wool. Reinstall the bobbin case and the needle plate. Put the bobbin in the machine so that it turns counter clockwise when you pull the thread. Rethread the top of the machine and change the needle. Hold the needle thread , turn the handwheel and see if the bobbin thread is picked up without snagging anyplace. If it's okay, sew away.
sewman7
Jul 14, 2008 | Singer 7422
Singer 7422 bobbin thread bunching up
I assume you checked to see there are no needle bits in the bobbin case holder.
Without looking at the machine it is difficult to diagnose the problem. It could be any one or a combination of problems, timing, needle bar height, damage to the hook and base etc.
I strongly suggest you have it looked at by a sewing machine tech.
Mar 29, 2008 | Singer 7422
Singer Futura CE100 Embroidery
check to be sure machine is being threaded correctly first, then when pressure foot is lowered pull thread and see if you are getting tension, if not assembly is bad
Jan 21, 2008 | Singer 7422
Sewing Machines Logo
29 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
