Question about The Office Equipment & Supplies
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Posted on Aug 11, 2017
cns assoc
  • 677 Answers
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
Posted on Nov 07, 2009
Democritus
  • 120 Answers
SOURCE: What is service error B200?
According to Canon's documentation, this is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board; a physical hardware malfunction.
This is Canon's official stance on the error:
Turn off the machine, and unplug the power cord of the machine from the power supply. If the problem is not resolved, contact your Canon service representative.
After looking a bit more, I discovered that the B200 error is a Voltage High Error on the iP4500 chip. Try calling Canon tech support at 1-800-828-4040. If your printer is still under warranty, they will probably send you a new printhead or a new printer.
Posted on May 26, 2010
  • 37 Answers
SOURCE: Error Code B200
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
termistor
  • 85 Answers
SOURCE: "ink absorber is full contact
while the ink on the ink absorber is submitted and must be cleaned. disassemble the printer until the ink absorber is reached, remove the ink absorber, with an alcohol solution to clean the ink dissolve deposits. It is better to make this a specialist
Posted on Mar 31, 2011
  • 5 Answers
SOURCE: I'm getting a b200 error
It is referenced on other message boards that the B200 error means "Printhead Temperature exceeded", which can be caused by an ink cartridge running out, yet the printer continues the operation. You could try unplugging the printer for a couple minutes to let it cool down, and try again. If it still has the error, you'll most likely have to send it in for repairs.
Posted on May 03, 2011
Error B200
Get steps to Fix Canon Printer Error Code B200 instantly. Watch below video to learn how to fix Error Code B200 on PIXMA Printer Call now +44-8000465291 for instant Printer help.
Source: https://goo.gl/xskzcB
For 4+ Cartridge Printers:
Step1:-Remove All Printer Cartridges.
Do remove the individual ink cartridges from your printer. This will be opening the lid of your printer and waiting for the cartridge cradle to be placed in the correct position.
Step2:-Remove the Print-head.
This is can be done by lifting the orange or gray locking lever on the side of the cartridge cradle and then gently lifting the print-head from the printer.
Get full Step by click below link
How to Fix Error Code B200 on Canon PIXMA Printers 44 8000465291
Feb 01, 2016 | Office Equipment & Supplies
My printer was out of ink I put new ink in and now it say printer error unplug an contact service center b 200. any way I can trouble shoot it myself I really need to print these important papers now
How to Fix Canon Pixma Support Code B200 Error Message
? 3:06
https://www.youtube.com/watch?v=jxhkgrozauY
Mar 5, 2014 - Uploaded by Refresh Cartridges
The Canon Pixma "Support Code B200" error message may also be accompanied by text stating "Contact ..
Nov 17, 2015 | Office Equipment & Supplies
Error code B200 PIXMA MX452
Error B200 is a print head overheat error. Just need a new printhead. You should see the power and alarm lights flash on and off 10 times then repeat the cycle. That's confirms the fault more than the error code. Its very simple to fit a head, just be careful putting the new one in as it's easy to break the pins in the carriage. No force is needed when fitting the head. Just let it drop in and lock the lever. Try taking out the old head first and gently clean the contacts at the back as they can rarely make poor contact with the carriage pins.
Good luck
Sep 22, 2014 | Canon Pixma MX452
Error b200 in cannon pixma 258, how to fix
VH monitor error or Error Code B200
Condition: The print head voltage is abnormal.
Problems and Solutions:
  • Replace Print head and logic board (Replace them at the same time.)
  • Replace Power supply unit
  • Check and Clean Head contact pin condition of the carriage unit
  • Check Cable connection especially the carriage FFC
Regards
Sep 26, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
Canon Printer Pixma MP540 with error code B200 - what can I do? Thank you for your support. Arthur
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
Feb 12, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Error code B200 on a MX850, what do i do?
Best solution for B200 error code:
http://www.youtube.com/watch?v=AyHaxjFg8aI
May 12, 2008 | Office Equipment & Supplies
55 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
