Question about Vacuums
Vacuum turn off by itself after few minutes ,after a while start again,is a renaissance c104h
reddevil6
  • 1673 Answers
SOURCE: Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Posted on Jan 24, 2008
  • 7 Answers
SOURCE: Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Posted on Oct 29, 2008
  • 97 Answers
SOURCE: CLEANER SWITCHES ITSELF OFF AFTER A FEW MINUTES
check all filters, if they can be washed do so, if not clean or replace. next check for a clog in the machine and in the hoses. the machine as a thermal device that if it senses an overload or getting to hot, the machine will shut itself off for safety resons.
Posted on Jul 29, 2009
  • 204 Answers
SOURCE: VACUUM ONLY WORKS FOR 45 SECONDS THEN TURN OFF
Sounds like it overheats quickly. But why are you not able to return it?
Posted on Feb 09, 2010
  • 694 Answers
SOURCE: vacuum goes on for a
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Posted on Apr 07, 2011
Testimonial: "This was absolutely terrific. I turned the dial on the top of my vacuum as was told to me and then turned the vacuum on. Right now it is working p"
I have a renaissance cansiter vacuum. When I plug in the canis ter no hose attached, it does not come on like it shouldn't , however when I attached the hose and wand I turn it on it will start to ru
It is running properly if you are doing what you say you are.
It should NOT run without the hose and should with it plugged in if the electronics in the hose and vac are working properly. This was the major problem with the Renaissance Model and was only manufactured for a few years.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Dec 07, 2014 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
The vacuum cleaner works for a few minutes then shuts off.After a few minutes it will start again,but soon shuts off again.
There may be as many as three air filters in the vacuum. Remove and thoroughly clean all of them and try again.
Gary
Apr 18, 2011 | Hoover Vacuums
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 | Vacuums
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
CUTTING OFF
Ok What is probably causing the problem is an internal error inside the vacuum. What I recomend you to do is take it back where you bought it and tell them what ever is wrong with it.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Hope it works! Tell me if you have any questions later on!
Jun 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Electolux renaissance
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=576614
Generic problem for all Vacuums
Electrolux renaissance
Posted by maryannn2l on May 06, 2008
No power when I plug into outlet
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have 3 problems that I can see. You may have a bad electrical outlet, but I doubt it, the bad cordwinder cord or a short in the cordwinder itself, or a connection came loose in the motor section. If you need further assistance then contact your local vacuum cleaner dealer in your area or contact the Electrolux factory listed below. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
